BIG BLOCK FORD 605
mbrucestang
Letson54
2POWERADDERS
BIG BLOCK FORD 605
TEA A 460 HEADS
WW BILLIT ROCKERS
PUSHRODS
ROLLER LIFTERS
NITROUS CAMSHAFT
PORTED INTAKE
NX FOGGER
PRO SYSTEMS SV1 CARB 1450 CFM
TRICK FLOW VALVE COVERS
605 INCH ENGINE
ELIMINATOR PREMIER BLOCK
OLIVER RODS
SCAT 4.500 CRANK
DIAMOND PISTONS
JEFF JOHNSON OIL PAN
AUSTRAILIN POWER PARTS TIMING BELT DRIVE
TITAN OIL PUMP
MSD DISTRUBITER
POWERMASTER STARTER
ATI BALANCER
SFI FLEX PLATE
8INCH CONVERTOR
STOCK CASE POWERGLIDE WITH ULTRA BELL
STRAIT CUT 1.80 GEARS
4340 OUTPUT SHAFT
I AM LOOKING TO SELL THE TOP END AS A SET, THE BLOCK CRANK PISTONS AND RODS AS A SET, I WILL SEPERATE THE FOLLOWING ITEMS ( OIL PUMP,OIL PAN, DIST, FRONT BELT TIMING COVER, STARTER)
CALL BRIAN FOR PRICES AND TO SEE WHAT KIND OF DEAL WE CAN WORK
THANKS
703 895 6468
WW BILLIT ROCKERS
PUSHRODS
ROLLER LIFTERS
NITROUS CAMSHAFT
PORTED INTAKE
NX FOGGER
605 INCH ENGINE
OLIVER RODS
SCAT 4.500 CRANK
DIAMOND PISTONS
TITAN OIL PUMP
MSD DISTRUBITER
POWERMASTER STARTER
ATI BALANCER
SFI FLEX PLATE
8INCH CONVERTOR
4340 OUTPUT SHAFT
THANKS
703 895 6468
2POWERADDERS- Posts : 51
Re: BIG BLOCK FORD 605
Please post pics, price and location.
schmitty- Posts : 4538
i will try to get some pics tomorrow
605 parts
Is this engine set up for fox body mustang by any chance ? im interested in alot of stuff if it is!
mbrucestang- Posts : 10
JUST GIVE ME A CALL WE CAN TALK ABOUT WHAT YOU NEED... 703 895 6468
i am in manassas va,
i want 6000 for the shortblock, block-pistons-rods-crank
i want 6500 for the top end heads-rockers-valve covers-pushrods-roller lifters- camshaft, and carb
i want 650 for the front cover belt drive
i want 2000 for the trans pg with jw bell shifter,cooler, and convertor
any questions just call or text brian 703 895 6468
last time i visited centreville va , i had to leave the inlaws and found a speed shop in manassas and spent several hours there ......... good luck with the sale
yea... Carol is a good friend of mine.... i have know the guys at c and c for 20 plus years
Sent you a pm. Thanks!
windsor- Posts : 1167
Is the SV-1 gas/alky and did you like it on the 605?
Will u separate Carb? How much?
fatal addiction- Posts : 433
» New 57 Ford Project Should we go big block or small block? Pics added
» big block ford parts,and sb ford
» 605'' big block ford
» 514 Ford Bi Block
» 545 cid Big Block Ford
» 514 Ford Bi Block
