any luck with Race Pumps fuel pump ?
jc10000rpm
any luck with Race Pumps fuel pump ? Empty any luck with Race Pumps fuel pump ?
Post  jc10000rpm January 22nd 2013, 2:44 am
anyone know of success stories with this pump ?? http://www.summitracing.com/parts/rpu-1800/overview/make/ford
jc10000rpm
any luck with Race Pumps fuel pump ? Empty Re: any luck with Race Pumps fuel pump ?
Post  dfree383 January 22nd 2013, 3:36 am
I have never seen one used on a BBF.
I can't imagine a pump with that kind of volumn is easy on a fuel pump excentric.
Most people requiring that kind of volumn either use an electric pump or belt driven pump.
Post  bbf-falcon January 22nd 2013, 5:58 am
On a street driven car it would probably work, but on a race car it would steal HP.
Post  P.Lafferty January 22nd 2013, 9:10 am
Constant problem with vapor lock, spent alot of money trying everything they recommended. ended up sending it back.
P.Lafferty
Post  rmcomprandy January 22nd 2013, 11:07 am
Used it on a small block Ford street rod with F.I. and it worked fine with a low pressure in tank pump feeding it.
Never tried it on any big blocks.
There are some racing associations which require a mechanical fuel pump and a cable driven one like used in NASCAR is usually way to pricey so, belt driven is the usual norm for high horsepower stuff..
Post  GaryS January 22nd 2013, 1:57 pm
Bought one in '08 for street 550HP 460 +.030 with QF 750 DP E85 carb. Plunger support housing wouldn't clear a full roller timing chain. Made another Race Pump adapter plate to offset the chain and still contact the cam. Pumped out the top of a ATL 44 gallon fuel cell. Constantly loosing prime or vapor locked. Never park with the front of the car up a hill!!! I always carried a gallon of fuel to prime. Never any issues with high RPM fuel supply or pressure. Bought it for mechanical reliability over electric. After 7500 miles of dicking with it, sold it. Changing to EFI and needed a different system anyway.
GaryS
GaryS
Post  jc10000rpm January 25th 2013, 2:06 am
the mechanical drag is amazingly low (according to what i hav read), also reportedly on some other forums and one video i found, the vapor lock problem was resolved by installing a return line with a restrictor jet in it. i was just hoping to find someone that has had recent success without relying on what u hear from the seller.
any more replies would be great
jc10000rpm
