junk in oil filters
junk in oil filters
Guys i've been cutting oil filters open for quite some time now And I'm all most all way finding copper or babit trash. But when every i tear down the motor i never see any thing from the bearings.
How many of you have the same thing?
Ace
Ace
powerstrokeace- Posts : 1496
filter junk
Ace, I've been cutting mine regularly for years- normally see quite a bit of really fine metal in the oil itself - makes it look like metal flake paint, sometimes a little small alum and iron in the botttom of the can, and not unusual to see a bit of aluminum in the pleats, I rarely see anything large enough to identify as copper in the filter. A lot of what I see depends on how many runs etc. Was always told if you can't read a part number on it don't worry about it! - But.... the last time I found some copper in the filter - 3 or 4 pieces, flat and thin, about 1/8" diameter, I dropped the pan and found a rod bearing with an issue- caught it just in time. that time. I've looked at alot of them out of other guys stuff and in my experience its pretty rare not to see a little something in them if they have many runs on them. Just my experience.
Kurt
Kurt
504T- Posts : 64
Re: junk in oil filters
If i'm not having a problem,I don't cut mine open.Just something else to wakeup in the middle of the night to worry about.When I make the FINAL teardown I cut it open and have a look see.
Are you sure it's not just bronze from the distributor gear?
BigBlockRanger- Posts : 1267
BigBlockRanger wrote:Are you sure it's not just bronze from the distributor gear?
This is what I noticed most on other builds. My 514 just had a bunch of lint and assembly goop in it after I cut open the filter after the first fire up...
jbozzelle- Posts : 3705
Most likely that's what it is. Very fine metal flake looking from both motors.
I never thought of the bronze gear
Ace
» "No By-pass" Oil Filters
» what are you guys using for oil filters ?
» Jomar oil Filters
» Fram Oil Filters......
» jomar filters
» Jomar oil Filters
» jomar filters
