Tube or no tube ?
whitefield
Tube or no tube ? Empty Tube or no tube ?
Post  whitefield February 1st 2013, 10:32 am
I have used the M/T ET streets without tubes in the past ,but was just wanting to know if I should start using the tubes ?
I also was wanting to know if I should use the wheel screws as well ?
whitefield
whitefield
Tube or no tube ? Empty Re: Tube or no tube ?
Post  richter69 February 1st 2013, 10:33 am
if u need to stiffen the sidewall some use tubes, if u use tubes you def have to screw um...........Id screw um anyway.
Post  whitefield February 1st 2013, 10:50 am
richter69 wrote:if u need to stiffen the sidewall some use tubes, if u use tubes you def have to screw um...........Id screw um anyway.
Running Cal Tracs and a 15X10 wheel with 4.11 gear, so which would be better to run ? 28/11.50 or 28/12.50 tire ?
whitefield
whitefield
Post  whatbumper February 1st 2013, 11:38 am
on the ET streets, I would run the 12.5's
Post  whitefield February 1st 2013, 12:52 pm
Stiff side wall or not with this set up ?
whitefield
whitefield
Post  whatbumper February 1st 2013, 2:31 pm
Et streets are stiff sidewall. Unless they've changed.
Post  Larry Williams February 1st 2013, 3:56 pm
when you install the screws, make sure they are opposite each other in the rim. race pages had a great article by dave morgan on this.
Larry Williams
Larry Williams
Post  whitefield February 1st 2013, 3:59 pm
Larry Williams wrote:when you install the screws, make sure they are opposite each other in the rim. race pages had a great article by dave morgan on this.
Thanks ! I will check it out , do you know what month ?
whitefield
whitefield
Post  70FB February 1st 2013, 8:13 pm
I have a set of MT tubes sitting here. I used them behind a set of 28X13.5 15 ET streets. They are in the garage and out of the sun. Put them on CL a while back but no calls. They are yours free if you come get them....I'm on a radial now.
70FB
70FB
Post  richter69 February 1st 2013, 8:14 pm
same
Post  IDT-572 February 1st 2013, 9:18 pm
You need stiff side wall, tubes, when you run a heavy car, big torque, or both. Screws are just a good safety idea regardless of power.
As speed increases the tire narrows and pulls the bead inward trying to unseat. Low air pressure adds to this problem.
Your Fairlane with the big block and a three speed would be where you would need screws and tubes or a stiff wall.
I ran tubes and screws with a 12 inch rim at 13 1/2 to 14 lbs of air when I ran my 28x10.5 Micky's regular sidewall.
Hopes this helps..........
Post  Larry Williams February 1st 2013, 9:40 pm
i just checked november/january/february and march its not in them. I will keep looking.
ok October is part 3 of suspension set ups. It is mentioned in there. would be a good idea to start reading from august on.
Larry Williams
Larry Williams
Post  whitefield February 1st 2013, 10:52 pm
Larry Williams wrote:i just checked november/january/february and march its not in them. I will keep looking.
I will and thanks for taking the time to look for it !
whitefield
whitefield
Post  whitefield February 1st 2013, 10:55 pm
[quote="70FB"]I have a set of MT tubes sitting here. I used them behind a set of 28X13.5 15 ET streets. They are in the garage and out of the sun. Put them on CL a while back but no calls. They are yours free if you come get them....I'm on a radial now.[/quote
Thanks for the offer ! I would pay shipping if you want to give them away.
whitefield
whitefield
Post  70FB February 1st 2013, 11:04 pm
let me check them out to make sure tomorrow and I'll get back with you. I went in to work at 5 this morning and still here.
70FB
70FB
Post  70FB February 1st 2013, 11:06 pm
70FB wrote:let me check them out to make sure tomorrow and I'll get back with you. I went in to work at 5 this morning and still here.
They are MTT-9555's in summit.
70FB
70FB
Post  whitefield February 1st 2013, 11:06 pm
IDT-572 wrote:You need stiff side wall, tubes, when you run a heavy car, big torque, or both. Screws are just a good safety idea regardless of power.
It does help , I just have to do some more home work to see if the 28/12.50s will fit the wheel well . I know the 28/11.50s fit.
Thanks Whitey
whitefield
whitefield
Post  whitefield February 1st 2013, 11:10 pm
Sorry about that ! Thats fine no rush, I orderd my wheels this week and they are being ship direct to me from the vender. So who knows how long it will take or when they will get here.
Thanks Whitey
whitefield
whitefield
Post  whatbumper February 1st 2013, 11:22 pm
You originally posted about et streets. Those are all stiff sidewalls and are rated differently than the et drags. The 28-12.5's measure the same as the 28-10.5 slicks. Unless you have a strange wheel backspace you will have a lot of room.
Post  whitefield February 1st 2013, 11:37 pm
whatbumper wrote:You originally posted about et streets. Those are all stiff sidewalls and are rated differently than the et drags. The 28-12.5's measure the same as the 28-10.5 slicks. Unless you have a strange wheel backspace you will have a lot of room.
Yes I am going to run the et streets 28/11.50 Not the drag or drag radial 28/11.50 et street is what I had on the car before . long story short I took the car apart and I am hoping that I rememberd and orderd the right back spacing.! I hope there is enough room for the 28/12.50.
whitefield
whitefield
Post  whatbumper February 2nd 2013, 10:08 am
Makes sense.
What bs and wheel size did you get?
Post  whitefield February 3rd 2013, 12:27 am
whatbumper wrote:Makes sense.
It is on a 64 fairlane thats been mini tubbed and I ordered them with a 4.5 bs.
whitefield
whitefield
Post  whitefield April 10th 2013, 11:28 am
How many screws do you or should be run on a 28.0 /11.50 /15 M/t ?
whitefield
whitefield
Post  IDT-572 April 10th 2013, 11:36 am
8 per side unless you are running high hp heavy car on a wider rim, then I would add more.
Post  whitefield April 10th 2013, 11:52 am
IDT-572 wrote:8 per side unless you are running high hp heavy car on a wider rim, then I would add more.
Ok Thats good to know because thats what I did and was affraid that I had messed up ! thanks
whitefield
whitefield
