trans cooler
whitefield
tconnection
trans cooler
Is it a good idea to use the trans cooler that's built into the radiator or is it best to use a seperate cooler?
tconnection- Posts : 866
Re: trans cooler
tconnection wrote:Is it a good idea to use the trans cooler that's built into the radiator or is it best to use a seperate cooler?
Depends on application and what you are doing with the vehicle.
whitefield- Posts : 2244
Re: trans cooler
On an 1/8 mile only car we very seldom use them at all. Street car, I would use a stacked plate type no matter what.
whatbumper- Posts : 3024
Re: trans cooler
5500 converter, c6, 1/8 mile, drag only.
Re: trans cooler
I use one of the heat sink type, mounts under the car next to the trans. It dont need much.
Re: trans cooler
x2richter69 wrote:I use one of the heat sink type, mounts under the car next to the trans. It dont need much.
Re: trans cooler
I think a cooler trans is a better working longer lasting trans !
Re: trans cooler
If you tow to the lanes, make a hit, and tow back to the pit you don't put much heat in it. So I guess it depends on your application.
Re: trans cooler
whitefield wrote:I think a cooler trans is a better working longer lasting trans !
X2. High h.p. + high stall speed = high converter temp.
High converter temp. = fried trans fluid.
Fried trans fluid = shorter trans life.
JMO.
maverick- BBF CONTRIBUTOR
Re: trans cooler
Ok, thanks men.
