My old 466's Intake Questions !
Which intake would be the best for my 466 ported DOVE-C heads 13.5:1 compresion hyd flat tappet cam 614 lift on intake and exhaust 261 in 268 exh duration@.050 110 .
Which intake would be the better choice weiand Stealth intake or the Edelbrock Vic intake ?
whitefield- Posts : 2244
Re: My old 466's Intake Questions !
If your engine is going to spend most of it's real time above 4300-4400 rpm, then use the Victor. If your engine is going to spend most of it's real time below 4300 rpm, then use the dual plane Stealth. 4300-4400 rpm seems to be the "crossover point", with the engines I've dynoed, where one switches from a dual plane to a single plane manifold.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
I am not sure how to answere it rpm wise,but it will spend most of its time running the 1/8 mile. About 10 to 15% of the time going to cruise-in's or just hitting the back roads.
use the victor,Its nice to know its there if you need it. later change the cam and it will be even better
BOSS 429- Posts : 2372
victor for the win..........
I agree w/Charlie and the rest of the gang.Victor
» 302 intake questions
» victor intake questions
» tfs intake and cometic gasket questions
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» performer intake or iron scj intake
