BBF PARTS - B460 Heads, A460 HEADS - MUCH MORE
dr's wife racing
Mav-Rich
** PhotoBucket Link-- http://s1308.beta.photobucket.com/user/1Mavrich/library/Stuff%20For%20Sale
Motorsport B460 Heads - AND - Motorsport B460 Intake Manifold
2.200int 1.880exh 91cc Chambers(??)
I have Intake Gaskets, 7-Guide Plates and 15-Rocker Studs
These would be great on 500-530ish CI
Great Condition - Never Hurt(I switched to A460) -- $1500.00 OBO - SOLD
TFS A460 Heads - 10 Bolt - Complete (PN TFS 5441T802)
2.350int 1.880exh 91cc Chambers
Pocket Ported / Flowed by Charlie Evans - Have Flow Sheet
Just Freshened by Charlie - Excellent Condition - Never Hurt
(I went to 18 Bolt Heads and Block) -- $1750.00 OBO - SOLD
15-Comp Cams 1.7 Roller Rockers w/ Poly-Loks
(1 Broke, so I upgraded to HS Rockers) -- $150.00 OBO - SOLD
16-Harland Sharp 1.73 Roller Rockers - Milled (nicely) to clear Triple Springs
(I Switched to w-w Shaft-Mount) -- $175.00 OBO - SOLD
Jomar Stud Girdle for A460 Heads w/ Poly-Loks -- $100.00 OBO - SOLD
8ea-Comp Cams Hi-Tech Pushrods - 3/8" x 9.150 x .080 - $50.00 OBO
8ea Comp Cams Hi-Tech Pushrods - 3/8" x 9.650 x .080 - $50.00 OBO
8ea Comp Cams Hi-Tech Pushrods - 3/8" x 9.350 x .080 - $50.00 OBO
8ea Comp Cams Hi-Tech Pushrods - 3/8" x 9.750 x .080 - $50.00 OBO
15ea Comp Cams Endure-X Solid Roller Lifters - BBF
(I broke 1 - Switched to Elite Series) -- $200.00 OBO
BBF 4.125 Stroke Crank - FoMoco Cast Crank - Offset Ground by Lunati
BBF Ford Mains .010 - 2.200 Rods - Magged and Checked OK
by Adnee Brown @ Performance Crankshaft - Made approx 1100HP
with Rods below - I Changed Combo (Crank/Rods) -- $450.00 OBO
Brooks Aluminum Rods - 6.695 x .990 Pin x 2.200 Journal
Used in NA 529 BBF - Probably 60-70 1/8mi Passes
Great Condition - Never Hurt (Changed Crank & Combo) - $200.00 OBO
Richmond Gear 4.56 Pro Gear - Large Pinion - 40-50 1/8th mi Passes
Excellent used condition -- $175.00 OBO - SOLD
Ford 9" Pinion Support - Small Pinion
Complete w/ Bearings, Seal & Spacer -- $50.00 OBO
Strange Chromoly Pinion Yoke - Small Pinion -- $70.00 OBO -- SOLD[b]
Racepak Split Collar (4-Magnet) for Pinion Yoke
(Driveshaft Speed Sensor) -- $30.00 OBO
I have pics of everything, upon request -
Located in Crestwood (Louisville), KY
rtalley@arcomky.com
Call or Text 502-817-6518
Thanks! -- Richard[b][b]
rtalley@arcomky.com
Last edited by Mav-Rich on February 18th 2013, 9:33 pm; edited 7 times in total (Reason for editing : Mark Items that have Sold)
Re: BBF PARTS - B460 Heads, A460 HEADS - MUCH MORE
Pics and Flow sheets on the TFS heads?
PM Sent
NOTE: Please give me your Email Address (PM if you dont want to put it here) for Pics - I cant seem to get Pics to post. I dont know if they are too large, or what?.?.
Rich
502-817-6517
Rich
502-817-6517
You need to use a host for you pics. Photobucket.com or the like.
You load your pic onto that site and then link them here.
John Myrick- BBF CONTRIBUTOR
OK. That explains it - I will try to set that up later tonight. In the meantime, I emailed you the pics of the Heads and Flowsheet.
Rich
Rich
nothings come thru?
If it helps any bodys feelings here I've delt Mav rich before.He was very good to deal with. Send me the skinny on the pro gears shipped to 35555 fayett al thanks Ward
The Gears are in great shape. I just switched to a 389.
It looks like about $35 for Shipping UPS Ground.
Rich
Rich
** Photobucket Link -- http://s1308.beta.photobucket.com/user/1Mavrich/library/Stuff%20For%20Sale
Thanks!!
Rich
Thanks!!
Rich
Do you know what the spring specs are on the A460 heads? or a part #?
Thanks,
Jon
Thanks,
Jon
460bronco- Posts : 364
They are the 'blue stripe' springs that come on them from Trick Flow.
Fresh and just installed by Charlie Evans.
I actually have an extra brand new set, as well.
A460 Heads, HS Rockers and Jomar Girdles SOLD - I will remove those Photos from The PhotoBucket.
Also, I may be willing to trade some of the remaining stuff for Bang-Bangs.
Rich
Rich
Shoot me the pmt info on the gears.Thanks Ward
B460 Heads, Comp Rockers and 4.56 Pro Gears - SOLD - I will remove Pics from the Bucket - Rich
Rich,
I want to thank you again for the block. I almost have the short block together. I'll be looking at anything that you have for sale in the future.
Thanks again,
Dave
Thanks again,
Dave
Dave De- Posts : 797
Great. I'm glad you are happy with it. I should have my short block together this weekend.
Thanks!!
Rich
Thanks!!
Rich
BBF PARTS AND MUCH MORE
Thanks "Mav-Rich", your money is in the mail. MavMan,1970 Ford MaverickMav-Rich wrote:Pinion Yoke Sold - I will remove from Photobucket
1970 ford maverick- Posts : 180
do you still have crank and rods if so could you give me a call at 18644904571 thanks
robbie mav grabber- Posts : 34
BBF Parts
Thank You "Mav-Rich",the big brown truck has come and gone!,MavManMav-Rich wrote:Pinion Yoke Sold - I will remove from Photobucket
» 460 & B460 Heads and Other Parts
» New A460 Heads and Intake $2900 Shipped
» A460 race heads + parts
» BBF Race parts ROR SALE Premier block, A460 heads, danny bee ect.
