What sensor on iron scj intake?
What sensor on iron scj intake? Empty What sensor on iron scj intake?
Post  Calypso February 14th 2013, 1:38 pm
What would you measure from, what it looks like, manifold heat passage? This is red stock appearing -71 scj Mustang from the Hemmings article.
What sensor on iron scj intake? Scj
Calypso
What sensor on iron scj intake? Empty Re: What sensor on iron scj intake?
Post  jeffgfg February 14th 2013, 9:42 pm
I'm not sure what that sensor is for but on an original SCJ there is a plate that bolts to the exhaust crossover that has a coil of tubing that slips into the manifold and the other end of the tube goes to the choke housing. If I'm not mistaken it screws to the threaded part right that you can see just behind the choke housing. That's the best I can remember from when I had mine back in the 70's. Most guys just used the gasket to make a block off plate and eliminated it.
jeffgfg
Post  72puller February 15th 2013, 8:27 pm
You can see the fitting on the side of the carb were the the choke tube is supposed to go. Have no idea what that sensor would be for.
72puller
72puller
Post  BOSS 429 February 15th 2013, 9:33 pm
he's reading temp there
Post  crittersf1 February 15th 2013, 10:03 pm
BOSS 429 wrote:he's reading temp there
What he says.
crittersf1
crittersf1
Post  jeffgfg February 16th 2013, 12:39 pm
Kind of odd to read the temp at the exhaust cross over isn't it?? How close is it to actual exhaust temps?? Just wondering what it could be used for.
jeffgfg
