Lubes
+7
dexter532
LivermoreDave
charchar1207
11 posters
Lubes
I am finally putting together my 532 ci. Do you guys have any suggestions about what types of assembly lubricants I should use?
I am thinking about COMP's products...
charchar1207- Posts : 31
Re: Lubes
charchar1207 wrote:I am finally putting together my 532 ci. Do you guys have any suggestions about what types of assembly lubricants I should use?
Something slippery with really good film strength which doesn't run-off.
There are a lot of products which fit the bill ... I use Torco MPZ.
Re: Lubes
Johnson engine assembly lube, available at Autozone.
LivermoreDave- Posts : 972
Re: Lubes
What Randy said, but I remember back in the day when EVERYONE thought sTp was the shits. And actually it was,and I never had any problems w/it.
Re: Lubes
after I broke my engine in I use Mobil-1 full synthetic 10-40 no need for 50 weight with a Jomar oil filter
the Coug- Posts : 3055
Re: Lubes
EPW engine assembly lube and also engine break in oil. great products although not availible at your local auto bone....
dexter532- Posts : 15
Re: Lubes
bbf-falcon wrote:What Randy said, but I remember back in the day when EVERYONE thought sTp was the shits. And actually it was,and I never had any problems w/it.
X2 that all my Dad ever used and I have used the STP many time with no problems but the oil these days don't have the zinc in it like back in the day did.
Re: Lubes
Lem Evans wrote:Oil......I'd assume one would prime the engine before start up.
Yup I prime mine on the engine stand then again when I get it installed before I put the dizzy in.
Re: Lubes
69F100 wrote:Lem Evans wrote:Oil......I'd assume one would prime the engine before start up.
^^^^^^What he said.
Re: Lubes
ft cams need a lil sumthin on the lobes otherwise whatever type of oil your gonna run in it is good enough.
