Max effort combo? Started collected bits...:)
+9
procharger 528
Blownshotgun
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
We have a class over here called true street, car must be standard chassis....naturally aspirated, no tubs or engine bay mods of any kind, 3500 pound min weight.
The only car we can use has shocker towers similar to a 69 Mustang....
which cannot be cut.....
What power do you estimate we could make with the following;
Cast block
Wet sump, vac pump
Any Head, manifold, carbs
Any fuel
Cheers, George.
![Crying or Very sad](https://2img.net/i/fa/i/smiles/icon_cry.gif)
Cast block
Wet sump, vac pump
Any fuel
Cheers, George.
Blownshotgun- Posts : 51
Re: Max effort combo? Started collected bits...:)
With an unlimited budget and plenty of maintence..... 1200-1400 depending on the displacement should be achievable.
dfree383 wrote:With an unlimited budget and plenty of maintence..... 1200-1400 depending on the displacement should be achievable.
Not scared of maintenance but would rather not change valve springs every 3 runs....
![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif)
Would like to know if 1300 is possible, & what components it would take to get it there.
Phillip did a c460 headed one with a single 4 that did 1205 at 640", up grade to a sheet metal 2x4 set-up and maybe some Thor heads?
You should be able to get more than 3 runs out of valve springs, I'm more referring to don't expect to go a full season with nothing but oil changes !
![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif)
Do you think the Thors maybe too big for an N/A Deal?
What about the Profilers, are they worth the extra cost compared to the C's?
Unmolested shock towers are gonna make a good set of headers for that thing a "special kind of fun".
![Exclamation](https://2img.net/i/fa/i/smiles/icon_exclaim.gif)
maverick- BBF CONTRIBUTOR
maverick wrote:Unmolested shock towers are gonna make a good set of headers for that thing a "special kind of fun".![]()
So true!!! Not to mention the cost on HP.............
Blownshotgun wrote:dfree383 wrote:With an unlimited budget and plenty of maintence..... 1200-1400 depending on the displacement should be achievable.
Not scared of maintenance but would rather not change valve springs every 3 runs....![]()
You do not want to change valve springs every 3 runs but, you're not scared of maintenance.
![scratch](https://2img.net/i/fa/i/smiles/icon_scratch.png)
So, how about refreshing the entire engine every 15 runs or so ...? You would be building somewhat of a street Pro Stock type engine IF you are looking to be THE fast guy..
Otherwise ... "Max Effort" has an entirely different definition than what I am familiar with.
That's why i'm asking, to see what it would take.......it's purely hypothetical at the moment.
Could be wrong but i wouldn't think a 1300 hp 650 inch motor would need a complete overhaul every 15 runs?
If you can keep the rpm down, I wouldnt think the overhaul frequency would be that much, I'd think you could go 100 passes depending on the components, between teardowns and figure valve springs every 8-10 runs or so.
and as far as Thor heads being to big, out of the box they might be, but by the time the head guy is done with them they will be right.
This motor your looking for is not an off the shelf bolt together build.
Blownshotgun wrote:Do you think the Thors maybe too big for an N/A Deal?
WHY WOULD YOU EVEN THINK ABOUT A WEDGE HEAD?
WHY?
BOSS 429- Posts : 2371
Maybe a good reason why George is thinking wedge head, is because there is a lot of really good running big horsepower wedge headed engines out there,,,,with Thor,,, Pro-Filer,,, and C-D or E-460 heads on them.
Maybe another good reason is because he said, 69 Mustang with factory shock towers that were uncut. If my memory is correct, Kar Kraft had to cut and modify the factory shock towers to get the Boss engine in the engine bay of the Boss 429 cars.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
dfree383 wrote:If you can keep the rpm down, I wouldnt think the overhaul frequency would be that much, I'd think you could go 100 passes depending on the components, between teardowns and figure valve springs every 8-10 runs or so.
There is only 5 meetings per year, we'd probably only need to do 30 - 35 runs plus some testing.
BOSS 429 wrote:Blownshotgun wrote:Do you think the Thors maybe too big for an N/A Deal?
WHY?
It'll be a massive task just trying to fit a wedge head.
c.evans wrote:Maybe a good reason why George is thinking wedge head, is because there is a lot of really good running big horsepower wedge headed engines out there,,,,with Thor,,, Pro-Filer,,, and C-D or E-460 heads on them.
Charlie
Absolutely Charlie, i don't mind spending money on good components.....if we'd have to sacrifice a little horsepower for a little less maintenance so be it.
I've seen you guys make 1200 with c-heads, what i'd like to know is if we spend the extra money on better heads & intake how substantial the gains would be?
Thanks.
With the 35-40 run season, I'd say your major work would be a teardown in the off season for inspection and replacement (As necessary) and look at X number of valve spring changes and regular maintence during the season.
Your basicly looking at a typical PS motor program IMO.
double post
Charlie
Where does it say hes using a mustang?
No matter what headers will be a lot of work
Blownshotgun wrote:We have a class over here called true street, car must be standard chassis....naturally aspirated, no tubs or engine bay mods of any kind, 3500 pound min weight.
The only car we can use has shocker towers similar to a 69 Mustang....which cannot be cut.....
Cast block
Wet sump, vac pump
Any fuel
Cheers, George.
George says it in his first post, second paragraph.
Charlie
![Max effort combo? Started collected bits...:) 317980_10151357594984268_1397630032_n](https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash4/317980_10151357594984268_1397630032_n.jpg)
This is the body style i'm thinking of using guys.
he said "similar to a 69 mustang"......
XA falcon coupe nice car
you can fit a C headed engine into a xa with out to much problems..i have done it before i tube framed my xa.
a set of custom headers and a special made spark plug spanner and you are away....
![Cool](https://2img.net/i/fa/i/smiles/icon_cool.gif)
procharger 528- Posts : 45
I want one !!!
come down to this side of the world and they are nearly as common as a mustang....
![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
procharger 528 wrote:come down to this side of the world and they are nearly as common as a mustang....![]()
can you ship one for me?
![bounce](https://2img.net/i/fa/i/smiles/icon_bounce.gif)
The darn steering wheel is on the wrong side.
schmitty- Posts : 4538
schmitty wrote:The darn steering wheel is on the wrong side.![]()
It on the right side.... you need to remember they drive upside down.....
![cheers](https://2img.net/i/fa/i/smiles/icon_cheers.png)
Page 1 of 2 • 1, 2
» Low Buck, Low effort combo;)
» broken drill bits are mean
» max effort 460
» Max effort A429s
» it all started with a thanks then i went off
» max effort 460
» Max effort A429s
Page 1 of 2
