Accelerator Help,
Accelerator Help, Empty Accelerator Help,
Post  67460 March 1st 2013, 4:07 pm
I was able to get the Trans Blanket on, now I trying to get the Flex plate shield on, it the one piece about 3-1/2" wide and bolts to the front of the trans in about 4 spots, now my throttle arm that comes up in front of the fire wall that connects to the carburetor rod. I need a good floor mount cable gas pedal or any and all help to my problem. Thanks Melvin,
67460
67460
Accelerator Help, Empty Re: Accelerator Help,
Post  maverick March 1st 2013, 4:53 pm
Take a look at www.appliedracing.com
Look under "pedals and components".
Post  67460 March 1st 2013, 5:15 pm
Thanks maverick, the base mounted dragster throttle pedal look great, going to look into it, Also going to look at my current set up to see if I can modified it. Maybe move to the left than the right again. Laughing
67460
67460
Post  maverick March 1st 2013, 5:20 pm
Cool
Post  67460 March 2nd 2013, 9:17 pm
Is there any rules against the accelerator linkage arm in full throttle position going back into a opening cut for it in the fire wall?
67460
67460
Post  67460 March 4th 2013, 3:47 pm
67460 wrote:Is there any rules against the accelerator linkage arm in full throttle position going back into a opening cut for it in the fire wall?
OK Stupid ? Was having brain freeze there for a minute. Got it done and it is sturdy and tight, not a big fan of cable set ups. What I did was mount the OEM pedal on the inside of the fire wall and will be running the throttle linkage threw the fire wall to the carburetor. Some modification had to be done, cut and weld but not unlike the rest of the car.
67460
67460
Post  hillbillyerv March 6th 2013, 11:48 am
cant wait to see this lil kitty on the track! Cool
hillbillyerv
hillbillyerv
