can use this crank?
can use this crank?
i found a guy who has a crank with a 4.440 stroke and i was wondering if i could use my 6.700 h-beam rods and my je piistons 1.350 comp .ht . my block is a d1ve standard block has not been deck at all! what will the displacement of the motor be, and would i need to deck the block at all? or could i just use everything the way it is? let me know!
nitrous.f- Posts : 294
Re: can use this crank?
you would have to cut the deck height to10.28"
you would end up with 538 cu. in.
fastbarry- Posts : 72
fastbarry wrote:you would have to cut the deck height to10.28"
ok thanks!
or leave the deck alone and put a thin gasket on it.......
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» aluminum crank pulley and a crank trigger
» WTT hawks/RPM 4.5 stroke cast crank for 4.150/514 crank
» Scat/Motorsport 4.300 cast crank
