intake studs
intake studs
I am wanting to get studs for the corners of my intake and cannot find the overall length I need, if someone knows please do tell. I would just go and measure but I am an hour away from it and a road trip just for that is not an option right now.
95lightiningguy- Posts : 570
Re: intake studs
I have used replacement Chevy exhaust studs several times they were the perfect length.
Re: intake studs
Thanks Eric, I am gonna see if I can find some.
Re: intake studs
Chevy exhaust studs are the right length but only one i can get has a socket head and that takes away from the length of threads i need.
bigjohn2007- BBF CONTRIBUTOR
Re: intake studs
I believe Mr. GASKET has a set without the wrench end.
Re: intake studs
good steal treaded rod works great cut it to what length works best for you it is as strong as a grade 5 bolt.
Re: intake studs
I used 3" stainless steel set screws from McMaster-Carr. Work great. They have a 3/16 hex inside one end for easy install/remove.
Part # 92311A633
http://www.mcmaster.com/#92311a633/=na7cwz
Part # 92311A633
Re: intake studs
David Cole wrote:I used 3" stainless steel set screws from McMaster-Carr. Work great. They have a 3/16 hex inside one end for easy install/remove.
Part # 92311A633
thanks
» meziere pump ,A460 head studs,new style A460 intake
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» What intake bolts for a torker 2 intake?
» felpro intake gasket # for use with vicktor or tfs intake ?
» Intake manifold design ~vs~ Intake air temp.
