Looking for Alky drum pump
Tommyj466
What are you alky guys using to transfer from 55 gallon drum to cell or 5 gallon jugs ? Not looking to break the bank.
John Myrick- BBF CONTRIBUTOR
Re: Looking for Alky drum pump
This is what I use. Added a section of hose to the end to reach into fuel jug. Works good.
http://www.tractorsupply.com/en/store/gpireg%3B-rp-5-hand-pump
TJ
TJ
Tommyj466- Posts : 322
Northern Tools plastic drum pump don't have to worry about it rusting from the alky
I have a extra Holley black pump mounted above the barrel then to a 12v source.
I used to go through the cheap cast iron drum pumps on a regular basis. About 3 in 4 yrs or so. The sliding vanes would corrode and seize up.
Bought a nylon chemical pump. Costs more, but I've had this one for about 6 years now with no problems.
http://www.northerntool.com/shop/tools/product_396428_396428
Caught it on sale for $59 or so.
I have one of these as a backup, but never need it:
http://www.northerntool.com/shop/tools/product_200022224_200022224
David Cole wrote:I used to go through the cheap cast iron drum pumps on a regular basis. About 3 in 4 yrs or so. The sliding vanes would corrode and seize up.
That the same one we have the yellow one for alky never have gave us any problems had for about 2 years
i use this one. http://www.jegs.com/i/JEGS+Performance+Products/555/80240/10002/-1 it works for pumping it into the car from a 5 gal can too!
cool40 wrote:i use this one. http://www.jegs.com/i/JEGS+Performance+Products/555/80240/10002/-1 it works for pumping it into the car from a 5 gal can too!
Mine does to if the mouth of the can is big enough
Bought the same one yesterday
Thanks for the responses guys
