Data logger and 9" carrier
I bought this data logger a few years ago from Tim Murphy and never got around to installing it. I am going to a Racepak system that has a lot less bells and whistles. $300 to your door.
3.50 Pro Gear, 40 spline spool, through bolted aluminum Yukon case with Daytona 10 bolt pinion big bearing pinion with 35 spline forged 1350 yoke . Top of the line stuff. New with gears these things are about $1300, $850 delivered.
schmitty- Posts : 4538
Re: Data logger and 9" carrier
I'm interested in the data logger. Is there a part number I can look up and see what all it does and a little about how it works. I'd imagine they did not use USB cables or thumb drives back in 95
fe50stang- Posts : 132
The Data Logger is a Computech Tach Time. It has EGT, vacuum, oil pressure, g force, and driveshaft and engine rpm. I talked to the company a while back, and they had Windows based software for this system to analyze data.
Data logger is sold. Thanks Rich.
9" carrier still for sale, I will pull the gears out and separate if that helps.
