C6 modulator valve
C6 modulator valve Empty C6 modulator valve
Post  69F100 March 26th 2013, 12:16 pm
Which modulator valve would be best for a drag race only c6 trans .Mine has the orginal in it now and has alway done good but it is leaking fluid out of it now.So I know it needs replacing and wondering what everybody runs mine is stock except for the b&m shift kit and 4000 stall.
On a dip stick lokar is not worth a crap leak all the time and if someone has a part number for a factory dip stick and tube that would be great could go to the junk yard and get one but most of them are all bent up.Mne came out of a van and that dip stick is not going to work on a drag truck Evil or Very Mad
C6 modulator valve Empty C6 Modulator valve
Post  aquartlow March 26th 2013, 2:23 pm
I have always understood that the C6 modular with black stripe was the best option for performance, as far as a "stock style" vacuum modulator was concerned. Hope this helps, Todd
aquartlow
aquartlow
C6 modulator valve Empty Re: C6 modulator valve
Post  whitefield March 26th 2013, 4:30 pm
aquartlow wrote:I have always understood that the C6 modular with black stripe was the best option for performance, as far as a "stock style" vacuum modulator was concerned. Hope this helps, Todd
The black is for high vacum engine the green or black will hold gears longer and firm up shift feel over stock. Tci offers a white valve that is good. The Dipstick and tube can be had for abot 45 bucks new with a locking top from PTC BTE Dynamic Racing Transmissions . the stock style are a lot better than the Lokar in my opinion.
whitefield
whitefield
Post  69F100 March 28th 2013, 12:26 pm
going with a green ring but I learned something new on a c6 one has a push in type and the other has a srew in type I picked up a push in type which is the same as the trans that came out of the motorhome I have.I didn't even pay attention that my truck had the srew in type then I got to thinking we seen the numbers on the valve body when I put the shift kit in it a 74 model.The motorhome is a 86 model so some where in between 74 and 86 they changed the type of modulator valve.
C6 modulator valve Empty modulators
Post  manofmerc April 3rd 2013, 6:44 am
On the screw in modulators for c6s about the only one available is a white stripe .The screw in the modulator should be flush with the nipple for the vaccum hose .Turn it in a couple of turns and see how it shifts in drive .It really isnt so critical on a drag machine .You spend most of your time at wide open throttle .Doug Laughing
manofmerc
Post  bb429power April 16th 2013, 12:24 am
Can I use any color stripe as long as it's push in like my trans or will I run into fitment issues?
bb429power
bb429power
Post  69F100 April 16th 2013, 4:44 am
bb429power wrote:Can I use any color stripe as long as it's push in like my trans or will I run into fitment issues?
Yes as long as it fits the hole
