engine tec
bigjohn2007
lonewolf
engine tec Empty engine tec
Post  lonewolf March 27th 2013, 5:53 pm
I HAVE 68 MUSTANG COUPE BACK HALF FRONT HALF STRIPPED DOWNT TO RAILS MUSTANG 11 FRT END. PLAN RUNNING 1/8 MILE TRACK. I FOUND 460 30 OVER WITH A LOT OF MACHINE WORK DONE. BLOCK DEBURED -ALGINE BORE AN SUCH. STOCK HEADS PORTED BUT HAS CRANE ROCKER ARM CONVERSION KIT. ROD AN CRANK GROUND DOWN LIGHTEN BALANCE. WHAT WOULD BE A GOOD SET OF RINGS. CAM 520 LIFT HYD-C6 TRANS WITH 28 HUNDER STALL.
lonewolf
engine tec Empty Re: engine tec
Post  bbf-falcon March 27th 2013, 6:40 pm
COUG-NO.
Lonewolf,Welcome to the site. Very Happy
Post  rmcomprandy March 27th 2013, 6:43 pm
I can't hear you very well ... it must be too loud in here.
Use whatever rings are listed for your application in the Sealed Power, Speed-Pro catalog. You never said what dimension rings you need so, I presume it would be high performance for OEM replacement.
engine tec Empty CARB SIZE
Post  lonewolf March 30th 2013, 8:09 pm
ALSO NEED SOME HELP ON CARB SIZE. INTAKE IS A EDELBROCK AIR GAP ,466 STOCK RODS CRANK BUT HAVE BEEN LIGHTEN BALANCE USEING ARP BOLTS THRU OUT RUNNUNG ON 1/8 MILE TRACK WITH 30" SLICKS AN 4.88 GEARS. WHAT TO KEEP RPMS UNDER 6500. CARS SHOULD WIEGH ABOUT 2600LBS CAR IS BACK HALF WITH LADDER BARS. THOUGHT ABOUT STEALING QUICK FUEL 780 VACCUM OFF MY 72 MACK 351CJ BUT WOULD NEED A CARB FOR IT. FRIEND TOLD ME I WOULD NEED A 950 CARB BUT I THOUGHT WOULD BE TOO MUCH.
lonewolf
Post  bigjohn2007 March 30th 2013, 9:30 pm
Hint turn caps lock off. Very Happy
bigjohn2007
bigjohn2007
engine tec Empty ok
Post  lonewolf March 30th 2013, 11:23 pm
so that what too louds mean- Laughing
lonewolf
Post  richter69 March 30th 2013, 11:39 pm
Hell u aint nobody until the Coug has chewed your ass for havin the capslock on...... Very Happy
Post  69F100 March 31st 2013, 12:04 am
I would get a 1050 dom if it was me my 460 i started with a 850 that was not enough carb went to a 1050 make a world of differents
Post  dfree383 March 31st 2013, 1:10 am
A 950 hp would work well with the parts you've mentioned.
But a victor manifold and dominator will go faster also get rid of the hydraulic cam, have an appropriate mechanical one ground for it, you have a race car not a grocery getter.
engine tec Empty Thanks
Post  lonewolf March 31st 2013, 1:15 pm
I wish I had found this site sooner. The reason Im using a hdy cam is the heads have a Crane adj rocker kit that you use the stock pedestal mount. They said to use a hdy cam with no more than 530 lift. I live in a rural area in Southern Il an the local machine shop closed . So I'm trying to use what I have for now. Now the question is to 950 or 1050 confused
lonewolf
Post  dfree383 March 31st 2013, 1:52 pm
Pull the heads and take a ride over to Owensboro KY the guys over there will hook you up.
Ditch the Performer RPM and get a victor and a 1050 dominator.
Post  maverick March 31st 2013, 4:17 pm
What he said. ^^^^^^ Idea
Post  lonewolf April 4th 2013, 9:15 pm
I"m leaning toward 1050 carb but for now will stick with the heads an cam I have. Lone time ago when I ran a two barrel cleveland in stock class then when bracket racing started , I cut down a set 4bbl heads with a hand drill an a Crane rocker pedestal bit. Some how it ran Very Happy may try it later with these heads.
lonewolf
