Hey guys need all the help I can get new to engine building
Hey guys need all the help I can get new to engine building  Empty Hey guys need all the help I can get new to engine building
Post  jdfoxracing69 March 29th 2013, 5:20 pm
New to the 460 an not sure what kind of setup to run I. Plane on running every thing new ,what I have , 70s full size 460 block cast number D1VE-6015-A2B an not sure what I can put in it I.E crank length, cam, pistons ext I would like it to run in the 600hp range thank you
jdfoxracing69
Hey guys need all the help I can get new to engine building  Empty Re: Hey guys need all the help I can get new to engine building
Post  bbf-falcon March 29th 2013, 7:34 pm
Not hard at all. Its common to go as much as .080 on a d1 block,although at .080 it should have a sonic check. The block will accept a 4.500 stroke crank easily and some have gone even bigger. So,a 557" engine is easy w/stock block BBF. If 600/700 hp is what you are shooting for,that can also be achieved w/ported iron heads w/good vj.
