Trans for mud racing
+7
J.Toney
kjett
prosandguy
whitefield
FORDMUD
pigs521bbf
11 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Anyone have recomm on a company that makes good transmissions for mud drags? I need a transbrake in it. Please help.. Hughes? TCI Auto?
pigs521bbf- Posts : 173
Re: Trans for mud racing
if it is a 3 speed go with a Frank Merkl Trans Brake VB
whitefield- Posts : 2244
Who sells frank? Do you have any contact info? I want to go 3 speed. Like reverse shirt pattern
P R N 3 2 1
P R N 3 2 1
you can contact him here on the board, his name is his handle here. He is in Canada, and shipping can be a little bit of a hassle, but it is well worth it.
schmitty- Posts : 4538
pigs521bbf wrote:Who sells frank? Do you have any contact info? I want to go 3 speed. Like reverse shirt pattern
P R N 3 2 1
I'm thinking you meant PRN123, I believe you can only get a reverse pattern in a transbrake valve body.
You can get a good rebuilt c-6 and just have Franks valve body put into it.
prosandguy- Posts : 186
I'm with the rest on here. Go to the auction block and find the thread about Trans Brake valve bodies from Frank M. You won't be disappointed.
kjett- Posts : 1169
I've used a couple of the Broader Performance REV/brake VB's with good success. Whoever you use, make sure the linkage is lined up. http://www.broaderperformance.com/26-ford-c6-?ps_full_site=1
J.Toney- Posts : 398
has anyone had any problems with hughes?
any recommendations on who to buy from for torque converter??
pigs521bbf wrote:any recommendations on who to buy from for torque converter??
Andre Pontbriand, Edge Racing Converters.
68formalGT- Posts : 865
Or give a call to Lenny at Ultimate Converter Concepts or UCC for short
kjett- Posts : 1169
anyone have contact info for them? and whats the cost roughly?
Go to the main page, at the top you will see a link to UCC. He's a sponsor here
kjett- Posts : 1169
Www.edgeracingconverters.com. 1-888-350-3343
Fill out the questionnaire about what you have and are building and Andre will give you a call back to let you know what he thinks should be done to get you the results your after. Great customer service, I emailed him a question I had about adjusting my stall and the next day he had looked up my phone number from my records and called me instead of just emailing me back. You can't beat the service.
I have no experience with Edge, but I have used UCC in the past and will do in the future.
1. He is a sponsor here, that counts a lot with me.
2. He was great to deal with, convertor showed up on time, looked great and stalled where it was supposed to. I could not ask for anything more than that.
Whom ever you deal with have your converter built to work with YOUR combination, dont just pick one from a warehouse and hope it will work for you because there are alot of factors that play into building a converter for a 4x4, and a custom converter usually costs the same as an off the shelf one.
68formalGT wrote:Whom ever you deal with have your converter built to work with YOUR combination, dont just pick one from a warehouse and hope it will work for you because there are alot of factors that play into building a converter for a 4x4, and a custom converter usually costs the same as an off the shelf one.
ok i did call edge and i like them.. do you have transbrake in your bronco? what type of trans?
pigs521bbf wrote:68formalGT wrote:Whom ever you deal with have your converter built to work with YOUR combination, dont just pick one from a warehouse and hope it will work for you because there are alot of factors that play into building a converter for a 4x4, and a custom converter usually costs the same as an off the shelf one.
I'm foot braking a C6 with a manual reverce valve body. The rules I race by allows for a 4500 max stall and a transbrake but I'm still not using one.
68formalGT wrote:pigs521bbf wrote:68formalGT wrote:Whom ever you deal with have your converter built to work with YOUR combination, dont just pick one from a warehouse and hope it will work for you because there are alot of factors that play into building a converter for a 4x4, and a custom converter usually costs the same as an off the shelf one.
ok sweet.. thanks for all the info.. what kind of motor do you have in your bronco.. from your picture, it looks pretty bad ass!
pigs521bbf wrote:ok sweet.. thanks for all the info.. what kind of motor do you have in your bronco.. from your picture, it looks pretty bad ass!
60 over 460, 14:1 Diamond pistons, C9vE ported heads, solid flat tappet cam from Scotty J, Trick Flow Track Heat intake, holley HP 750 converted to e85, class rules specifies 750 carb going to a 750 Dominator.
https://www.youtube.com/watch?v=iW7duog8nHU&feature=youtube_gdata_player
68formalGT wrote:pigs521bbf wrote:ok sweet.. thanks for all the info.. what kind of motor do you have in your bronco.. from your picture, it looks pretty bad ass!
That bronco sounds mean!!! I like it. What size gears you run?
Where do you race at?
pigs521bbf wrote:68formalGT wrote:pigs521bbf wrote:ok sweet.. thanks for all the info.. what kind of motor do you have in your bronco.. from your picture, it looks pretty bad ass!
I'm maxed out on the Dana 44.
www.batcaveracing.com
68formalGT wrote:pigs521bbf wrote:68formalGT wrote:pigs521bbf wrote:ok sweet.. thanks for all the info.. what kind of motor do you have in your bronco.. from your picture, it looks pretty bad ass!
thats cool.. so i check out the website.. if you don't mind, how much hp and torque does your bronco put out??
I run one of my C-6's with a Merkle brake with absolutely no complaints. My converter is an ATI.
crittersf1- Posts : 521
The last converter I bought was a Fti its a nice peice!! The next one will be a billet aluminum chance bolt together!!
fatal addiction- Posts : 433
Page 1 of 2 • 1, 2
» trans problem for mud racing
» ? on C6 trans
» C6 trans
» Need a Transmission Rebuilder !!!
» 7.3 trans on a 7.5
» ? on C6 trans
» C6 trans
Page 1 of 2
