when is it time to change
when is it time to change Empty when is it time to change
Post  ironbark April 13th 2013, 7:43 pm
when is it time to change from a wet sump to external dry sump set up, does it depend on the rpm you are swinging too, or is it horsepower related.
ironbark
when is it time to change Empty Re: when is it time to change
Post  c.evans April 14th 2013, 12:57 am
Both, and also it's budget related. As a rough rule of thumb, maybe anything over 1000 Hp and over 7,400 rpm for an extended period of time, such as truck pullers. I mean we all know that dry sumps are better, it's just a matter of when do you want to take the plunge.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  ironbark April 14th 2013, 1:13 am
thanks mate
ironbark
Post  rmcomprandy April 14th 2013, 11:08 am
The higher the lateral G forces are on the vehicle ... the more a dry sump will help.
The trick is to maintain constant oil flow & pressure without the crankcase being so full of oil that it costs with oil aeration and horsepower.
