1985 Mustang Coupe/Notch 25.5 Roller
1985 Mustang Coupe/Notch 25.5 Roller Empty 1985 Mustang Coupe/Notch 25.5 Roller
Post  gryphon68 April 14th 2013, 10:54 am
1985 Mustang Coupe/Notch 25.5 Roller MustangLaunch
'85 Mustang Notch 25.5 Roller
$10,000
1985 Mustang Notchback (Clean Michigan Title, NOT Salvage)
25.5 Chro-Moly Cage by Ultimate Team Performance of
(Cert Expires April 2013)
Rust-Free Ex-Florida Car
Approx 2800# w/ Alum BBF (No Driver)
Fully wired:
Wired for 3 stages of Nitrous with Progressive Controller and Digiset
Cometic Dual Stage Progressive Nitrous Controller
(2) ARC Relay Modules
Over Head Switch Panel
Engine Compartment:
Remote Oil Filter Mount
Mounting Tab Locations for BBF and 5.4 Mod Engine Plates (No Plates included)
Offset SKRC Brake Master Cylinder Mounting Plate
Suspension/Chassis:
Team Z K-Member/A-Arms/Strange Coil Overs
Maximum Motorsports Caster/Camber Plates
Flaming River Manual Steering Rack
Lightweight Fabricated Steering Column
Strange Front Brakes
8.8 Axle 2" Shorter Per Side w/ 9" Big/Late Ends, Strange Axles
Team Z Rear Axle Upper and Lower Control Arms
Pro Mod Style Anti-Roll Bar
RaceCraft Drop Spindles
Motorsport Rear Disk Brakes
Powerglide Transmission Mount Crossmember
Wheels/Tires:
15x3.5" Monocoque Front Wheels
M/T ET Front Tires
15x10 6.5" BS Draglites (undrilled) w/ 275/60 DR's
Body/Exterior:
Fiberglass Decklid
Fiberglass Hood (Cut for Lexan Scoop)
Mini Tubs
Modified Quarter Panel to fit 315/60 tires
87+ Flush Quarter Windows
Simpson 10ft Skyjacker Parachute (black)
Chute Mount
Chute Anchor
Rear Wing (SKRC Center Section w/ Custom End Plates)
Interior:
Power Windows
Scott Rod Fab Black Aluminum Door Panels
RJS Quick Release 5-Point Harness
RJS Window Net
Quarter Turn Nitrous Shut-Off Valve
Grant Steering Wheel w/ Yellow Stripe
Steering Extension
Steering Quick Release Hub SFI
Chute Release Handle/Cable
Fuel System:
5 Gallon Fuel Cell
-10 Fuel Feed and Return Lines
Misc:
4" Aluminum Intercooler Piping for mounting Intercooler Over rear axle
Steel Elbow welded into Cowl, for Intercooler Pass-thru, with removable caps
Would need new v-band welded on Engine compartment side if it was going to be used.
gryphon68
