Which spark plug wires
+6
Dave C.
kjett
Beast
tconnection
10 posters
I need some long plug wires. Im gonna have to drape the wires down under the headers then up the front of the motor to the distributor.
Thanks for any info.
tconnection- Posts : 866
Re: Which spark plug wires
Anybody got some part numbers for some bbc under header plug wires.
Wires
This guy can hook you up. Supposed to be top notch wires.
http://www.firecore50.com/
Beast- Posts : 66
you can buy MSD wire in Rolls and kits for the ends.
http://www.summitracing.com/parts/msd-34019/overview/
I use the Moroso universal wire sets and they are long enough to fit under the headers and you can get them with whatever boot you want.
kjett- Posts : 1169
Has anybody used the MSD BBC under header wires?
I went with the Moroso BBC under header wires and fit real nice with my ahead deal.
soupbean- Posts : 637
I used the MSD Universal set # 31239 on my A460 head engine. Under the headers and around the front like described in the first post. One end is already installed (90° plug end). Cut to length and install the distributor end.
Comes with a crimper/stripping tool. All you need is a razor blade, vice for the crimper and a little WD-40 to make the boot install easy.
Sorry to dredge up an old thread but I's have a question. For you gent's that run the wires under the headers, do you have any wire organizers/supports to keep them from touching the headers?
TY Alan
TY Alan
Alan,
I use an MSD 8841 separator kit. One tube on my deal requires a flat bracket that bolts to the side mount hole on the block and has an 8841 fastened to the end of it. They are nice and simple . Maybe this link will work.
http://m.summitracing.com/parts/msd-8841/media
Thanks ,
Keith
Thanks ,
Keith
