Need D3 rocker arms
Need D3 rocker arms
I have a nice rebuilt set of D3 heads and a separate set of 5/16 by 7/16 screw in studs. I need a set of rocker arm assemblys and studs to fit the rocker arms if mine won't. Am redoing a mild 468 to sell.
Thanks .
Thanks .
GT300TD- BBF CONTRIBUTOR
Re: Need D3 rocker arms
Elgin sells new factory pedestal rockers for under $100 or so, but they bolt down, they are not stud mount.
Just thought someone had some layin' around or on a set of D3's they're gonna junk. I bought a "low mileage" 468 to refresh and I'm surprized it isn't painted yellow .
OPPS, just remembered it's a .560 lift cam, can't use stock rockers, sorry another rookie mistake . Bruno, you can deleat this post .
Thanks.
Thanks.
IIRC, you can use the rockers with that lift, I used them at almost .600 without issue. I know there is worry about pulling / breaking the 5/16 bolts/studs, but I never had a problem with mine. If you still need some, I may have a set lying around somewhere... LMK, and I'll take a look...
ThndrChkn- Posts : 2216
Yes I do.
Thanks .
I'm sure I got a set if you need them...
56Tbird- BBF CONTRIBUTOR
I'll take a look and see if I can find them...
Dang it!! Beat on a holeshot!!
Thanks Dano,
Thdrchkn, holeshot huh , thanks.
