Crane Ultra Pro Mechanical Roller Lifters 35570-16 are they any good
+6
Barney
norm
CHARLIEB
10 posters
Crane Ultra Pro Mechanical Roller Lifters 35570-16 are they any good  Empty Crane Ultra Pro Mechanical Roller Lifters 35570-16 are they any good
Post  CHARLIEB April 19th 2013, 7:44 pm
Hello I am building a brand new motor pump gas 598 cubic inch. I am needing to know that if these lifters are better than Comp Cam 836-16 lifters. Here is some Information of these Crane Ultra Pro Lifters. Tell me what you think.
They should be used in all drag race
applications with spring seat pressures in excess of 300 lbs., and open pressures over
800 lbs.
CHARLIEB
CHARLIEB
Crane Ultra Pro Mechanical Roller Lifters 35570-16 are they any good  Empty Re: Crane Ultra Pro Mechanical Roller Lifters 35570-16 are they any good
Post  norm April 19th 2013, 8:20 pm
I put enduramax Crowers in mine with A heads. Would not say they are "the best" but they are pretty good. "Best" can come down to opinion. There are a lot of good lifters available.
norm
norm
Post  CHARLIEB April 19th 2013, 8:25 pm
norm wrote:I put enduramax Crowers in mine with A heads. Would not say they are "the best" but they are pretty good. "Best" can come down to opinion. There are a lot of good lifters available.
Okay,Thanks. So Trade My Comp cams in for a set of those ?
CHARLIEB
CHARLIEB
Post  Curt April 19th 2013, 8:28 pm
Without a doubt, Jesel is the best lifter out there.
Post  CHARLIEB April 19th 2013, 8:30 pm
Curt wrote:Without a doubt, Jesel is the best lifter out there.
How much do they run?
CHARLIEB
CHARLIEB
Post  Lem Evans April 19th 2013, 8:43 pm
$1,500-$2,700 depending on the style and model.
Post  CHARLIEB April 19th 2013, 8:53 pm
Lem Evans wrote:$1,500-$2,700 depending on the style and model.
"WOW" Okay what is a lifter that will work good for the street around $800.00 or so
CHARLIEB
CHARLIEB
Post  CHARLIEB April 19th 2013, 9:04 pm
The reason I want to change from Comp Cam is because I am hearing a lot of bad things about them failing. Can someone in lighten me on the lifters and help me choose in which lifter to buy.
CHARLIEB
CHARLIEB
Post  rmcomprandy April 19th 2013, 9:40 pm
On the street with the high valve spring pressures of a competition roller camshaft valve train, there is NO roller lifter to survive high mileage street driving without constant maintenance and lifter rebuilding.
Post  Barney April 19th 2013, 11:44 pm
This^^^^. Jesels arrva really nice piece.
Barney
Barney
Post  CDMBill April 22nd 2013, 12:10 am
Given the cam specs you mentioned in your other post, I suspect the newer Comps with the pressurized pin oiling and tighter needle tolerances (same part number) would be fine for a couple of years. I used the Crane Ultra-pros for four years(2 sets) with one failure. 230# seat, 540# open 276/284*@.050 .800 lift. 1.8:1 rockers which matters. I had these before their 'reorganization' and they were a quality product.IMHO
CDMBill
Post  dfree383 April 22nd 2013, 12:19 am
If your going to drive it on the street alot, you need to consider street lobes, tight lash and softer springs. 300 / 800 is going to kill most anything driving in real steet conditions.
You need to decide if you want a Race car that you drive to the burgher stand once a year or a Street car you take to the track every once in a while.
Another suggestion if you think you need big big numbers, is to build a very mild engine and strap on a blower or turbos.
Post  cool40 April 22nd 2013, 12:51 am
i would not run a solid roller on the street.JMO Smile
Post  Dave C. April 22nd 2013, 7:41 am
I agree with cool40 . Two of my buddies built street rods with big blocks in em . They put solid rollers in em and have had a lot of trouble keeping them together.
Dave C.
Post  CHARLIEB April 22nd 2013, 8:50 pm
Well let me say this first, I want to thank each one of you for your input it does mean a lot to me.
CHARLIEB
CHARLIEB
