Tunnelram
Re: Tunnelram
Your post says alot of work done, can you please explain in a little more detail of the work done.
teacher- Posts : 4
tunnel ram
As tou can see a plate has been welded in the bottom and all the material has been removed between the runners.The front has been ground so a big cap dist will fit. Let me know and thanks for looking.steve
Re: Tunnelram
Steve,
Is this the same intake that you had the toilets on, if so the pictures look different the bare intake picture has two sets of holes in the runners and the one with the toilets just has one hole. The bare intake looks as if it has a flat piece of aluminum welded in and the other look like it has diamond plate. I guess the big question is will this intake fit 429A or SCJ heads I see you run "A" heads and blue thunders.
Jerry
Jerry
teacher- Posts : 4
Re: Tunnelram
I received the intake today, looks great, just as described by the seller. Steve is a good guy to deal with, good parts and fast shipping.
Thanks again, Steve
Thanks again, Steve
teacher- Posts : 4
intake
Thanks for the great sell,Hope you have great luck with it.That intake made a lot of trips to the winner circle. thanks again steve
