pass. side water pump
pass. side water pump Empty pass. side water pump
Post  maicoman April 27th 2013, 8:05 am
I've read that there is a pass. side outlet, short water pump but can not find one.Any tips on application? I got a great buy on a chevy radiator & am trying to keep the hoses as short as I can.
maicoman
pass. side water pump Empty Re: pass. side water pump
Post  rmcomprandy April 27th 2013, 10:07 am
maicoman wrote:I've read that there is a pass. side outlet, short water pump but can not find one. Any tips on application? I got a great buy on a chevy radiator & am trying to keep the hoses as short as I can.
You have heard wrong unless you mean an ELECTRIC pump.
Sell the radiator and get the correct one.
Post  crittersf1 April 28th 2013, 5:36 am
I agree.
crittersf1
crittersf1
Post  69F100 April 28th 2013, 1:54 pm
I have seen sbf with the outlet hose on the passager side but not a bbf with out going to the electric.
Post  petec April 28th 2013, 3:34 pm
Windsor family small blocks had passenger side intake pumps prior to 1970 but I don't think the 429-460 engines have that option in pumps. Also, on the Windsors, the timing marks and timing tab were moved to the other side when the pump redesign happened so if you changed the pump you had to change the harmonic balancer as well if you wanted to be able to see your timing marks.
petec
