EDELBROCK RPM NITROUS SOLENOID
EDELBROCK RPM NITROUS  SOLENOID Empty EDELBROCK RPM NITROUS SOLENOID
Post  10SHOTS April 29th 2013, 5:48 pm
will a edelbrock rpm solenoid with a .109 orfice flow good enough for a 102or 104 jet ?
10SHOTS
10SHOTS
EDELBROCK RPM NITROUS  SOLENOID Empty Re: EDELBROCK RPM NITROUS SOLENOID
Post  richter69 April 29th 2013, 6:48 pm
I've run those jets with that noid w no issues, just watch the jet spread as your gonna be close to the max the noid will flow......... trashcan time lol.
Post  whatbumper April 29th 2013, 7:09 pm
You can find trashcans on the market now for pretty cheap. I know a lot of texas guys are going with the nos wizard stuff so they are dumping their old stuff.
Post  Induction-Solutions May 7th 2013, 3:30 pm
10SHOTS wrote:will a edelbrock rpm solenoid with a .109 orfice flow good enough for a 102or 104 jet ?
Yes, it can actually support even more then that because of reduced back pressure after the orifice as well. Bottom line though is the closer you get to the orifice size of the solenoid the less return you get. This also requires bigger jet spreads too to get the tune up correct.. We sell a bad ass Trash can if you want to go that route too..
http://inductionsolutions.com/shop/solenoids/a-the-trash-can-nitrous-solenoid/
Hope this helps.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
Post  10SHOTS May 9th 2013, 4:30 pm
is it worth a change to go with your .120 side exit noid ?
10SHOTS
10SHOTS
Post  richter69 May 9th 2013, 4:56 pm
Id just buy a trashcan and a -6 feed line and roll with it.............
Post  Induction-Solutions May 10th 2013, 9:06 am
You should see gains even with that solenoid.. SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
