Transbrake VS RMVB
colormebad
Transbrake VS RMVB
Would a person not be better off using a Reverse Manual Valve Body' Running a C4 trans...I know how how these little C4 leaves the line , and thought the RMVB would be easier on the clutches & the trans than a transbrake...Going to be spraying 2 foggers also ....
colormebad- Posts : 262
Re: Transbrake VS RMVB
I dont think it will matter, the direct clutches seem to be the weak link in that deal. When you get tired of replacing them everytime you turn around you'll be ready for one of them 2 speed deals........
and why would it be easier on the clutches? except that you would be leaving a 2/3 the rpm
Frank Merkl- Posts : 1524
In my opinion the trans brake is not the problem with the c-4 not holding up. The problem is running to much power throught a small package. At a certain level you will either have to go to a c-6 , TH400 or PG.
The C-4 is a good unit up until about 700 sbf flywheel hp after that it is just on borowwed time. And at that hp with a sbf it will only get you about 50 to 100 passes. thats just my 2 cents
whitefield- Posts : 2244
Im fixin to put my c4 on sbf borrowed time real soon.....
richter69 wrote:Im fixin to put my c4 on sbf borrowed time real soon.....
I was going to run a C-4 in my 64 ,but decided with the changes that I have made. I am running the C6 with the big block .
Here the reason C4's won't that the hp a C6 will, the inside ones are pics the direct clutches in a C4 even with 6 clutches they wouldn't hold what 7 clutches ( the outside ones ) will hold !!
X2 Me too
Update
its being assembled...... hope to have it on the run stand soon pending headgasket availability.......
richter69 wrote:its being assembled...... hope to have it on the run stand soon pending headgasket availability.......
Interested on how it turns out !
whitefield wrote:richter69 wrote:its being assembled...... hope to have it on the run stand soon pending headgasket availability.......
I'll spray it as hard as needed to run what it needs to lol.
Heck Yeah !
You still running Transking VB ? I am thinking about trying one!
Spray the rods out of that bitch
John Myrick- BBF CONTRIBUTOR
whitefield wrote:Heck Yeah !
yes, works awesome, its an older one though I hear TK sucks now.
richter69 wrote:whitefield wrote:Heck Yeah !
That's what I am running in to with just about every c-4 brake vb . The older VB,s work better than the newer ones. I sold mine to a customer and got another one and it doesn't work as well as my old one
» Any pics of the 'Merkl mod' to the TCI RMVB w/ brake?
» C6 pro transbrake
» Transbrake
» Merkl transbrake
» C4 transbrake
» C6 pro transbrake
» Transbrake
» Merkl transbrake
» C4 transbrake
