P-51 / cam
glenevans
P-51 / cam Empty P-51 / cam
Post  glenevans May 8th 2013, 11:51 pm
Thinking of upgrading to P-51 heads and new flat top pistons for my 545. Would be close to 13.8 - 14 compression. Wondering if my current flat tappet cam .648 lift 262* duration @ .050 would work ok.
glenevans
P-51 / cam Empty Re: P-51 / cam
Post  bbf-falcon May 9th 2013, 12:01 am
Are you estimating C/R? Suspect
Post  glenevans May 9th 2013, 12:15 am
14.03 based on Wallace Racing calculator with 3cc piston (probe), zero deck, 72cc chamber. I had figured it a week ago, so knew it was right in that range, based on their program. Smile
glenevans
Post  bbf-falcon May 9th 2013, 12:24 am
Whats the B/S?
Post  dfree383 May 9th 2013, 12:26 am
It will work, but its definetly not right.
Cams a little small for a race car and you need to make sure the probe's have the correct valve relief.
Post  bbf-falcon May 9th 2013, 12:46 am
glenevans wrote:14.03 based on Wallace Racing calculator with 3cc piston (probe), zero deck, 72cc chamber. I had figured it a week ago, so knew it was right in that range, based on their program. Smile
You are right.I just seen where you had a 545. Wink
Post  glenevans May 9th 2013, 12:49 am
4.39" bore, 4.50" stroke. I just have never had a roller cam......
glenevans
Post  dfree383 May 9th 2013, 12:56 am
Now would be a good time to get one IMO.
Post  glenevans May 9th 2013, 1:01 am
probably right ......
glenevans
Post  bigjohn2007 May 11th 2013, 8:56 am
dfree383 wrote:It will work, but its definetly not right.
x2
bigjohn2007
bigjohn2007
Post  4thHorseman May 13th 2013, 10:14 am
Yeah, with that cam you're leaving about 100 thou's valve lift on the table. You'd be much happier to step it up.
4thHorseman
4thHorseman
Post  glenevans May 13th 2013, 4:56 pm
Sweet car 4th Horse, but I'm biased to '69 fastbacks w/boss 9 scoops ( Mine is Wimbledon white ) Smile what size cam do you run ?
glenevans
Post  4thHorseman May 15th 2013, 12:29 pm
It's a comp cams solid roller stick with specs by Kaase suited to my car's heavy weight and high altitude where I'm at. It has a 109 cl and lift in the .760 area with 280 duration at .050. I have the cam card someplace in my shop but I'm at work now.
4thHorseman
4thHorseman
Post  Lem Evans May 15th 2013, 1:05 pm
Is this a drag race deal? What is your conv. stall?
Post  glenevans May 15th 2013, 2:40 pm
I do mostly bracket racing with the car, but occasionally drive on street. I have an 8" continental converter, 4900 stall. 4.11 gears, wide ratio c6, full weight 1969 mach 1. Currently crosses finish line @ 6400 rpm w/ dove-c heads , 2" crites headers. Footbrake start. Also high elevation here in SLC, Utah about 4400 ft.
glenevans
Post  glenevans May 15th 2013, 4:58 pm
crank is scat cast 9000 series, so probably need to limit rpm's
glenevans
Post  Lem Evans May 15th 2013, 5:15 pm
glenevans wrote:I do mostly bracket racing with the car, but occasionally drive on street. I have an 8" continental converter, 4900 stall. 4.11 gears, wide ratio c6, full weight 1969 mach 1. Currently crosses finish line @ 6400 rpm w/ dove-c heads , 2" crites headers. Footbrake start. Also high elevation here in SLC, Utah about 4400 ft.
Vacuum brakes?
Post  glenevans May 15th 2013, 5:24 pm
I converted to manual brakes ('74 maverick disc / drum master cylinder), manual steering and no A/C.
glenevans
Post  Lem Evans May 15th 2013, 7:29 pm
I apologize for asking so many questions but, many times it aint about caming the engine. It's about caming a guys combination.
1] 4900 Vs 5600 stall.
2] Foot brake Vs transbrake.
3] 4400 Elv. Vs 400 Elv.
4] 3400 lbs Vs 2400 lbs
There is not one answer given the variables.
Post  glenevans May 15th 2013, 9:00 pm
I do appreciate the time and info that has been given here. Yes, I do agree with you Lem that the combo needs consideration to properly cam and build the engine. I sort of started out thinking I would drive this car more on the street, but it has been leaning toward racing only. I guess the overall goal with this particular car would be low to mid 10 sec. quarter mile times after getting the good heads, mafia intake etc. Smile
glenevans
