Thanks for letting me in.
zrob90sc
I'm Zach. I'm new to the big block stuff. I've made pretty good power with a 4v 351c, but found a 1969 460 out of a lincoln for if/when I blow the cleve up. It's for a strip only torino. This'll be a stock stroke solid roller deal. I ported my 4v heads to flow 330cfm which didn't require much.
Got a couple questions. Do the c9 heads require a lot of work to get in the 330-350cfm range? Are they like a cleveland and need more work on the exhaust port? Also how high would I have to spin to get 600hp out of a stock stroke motor?
zrob90sc- Posts : 43
Re: Thanks for letting me in.
Welcome to the site the c9 heads need exh work also I spun my 460 6500rpm never hurt it but if was building a race engine get some new rods to be on the safe side.flow on the heads i will have to get some of the head porters to answer that.My 460 I in my ranger was stock bottom end except for the flat top pistons with a custom solid flat tappet cam with dove c head they are the same as the c9 heads truck wt 3265 ran the best of 6.71 in the 1/8 so yes you should be able to 600hp out of it
Thats moving pretty good! I hear you on the rods, have too much money in my stock 351c rods. I'm going aftermarket this time. If you don't mind me asking how much cam/compression and gear do you have in that combo?
Welcome to the site . Good to see other Torino guys on here. How fast is the Cleveland combo ? Got any pics?
Dave C.- Posts : 1268
The compression was 12.1 with elcheapo speed pro pistons the cam .649in and .642exh duro @.050 260in and 271exh adver duro 290in 304exh intake ffr G429 like the victor intake 1050 apd alky carb the dove-c heads is home ported on the exh side only with the humps removed open up to header gasket and bowls cleaned up intake port only opened up to match a 1231 scj gasket with ss valve stock size ran a stock c6 trans with a cheap b&m shift kit and tci 10'' 4000 stall with a 4.86 gear.I have now changed my combo to a 552 and 4.30 gear going to freshen the 460 and put it in my 69f100 this winter or summer.
Hi Dave, torinos rule! I'm just finishing up the drivetrain in this car and haven't ran it yet. The engine made a little over 500hp and the car weighs around 3400( i think). I haven't weighed it since we put a cage in it. It's got a built c6, 5000 stall and 4.57 gears. All I'm waiting on is a driveshaft plus s new front windshield and its off to the strip. Hoping for low 7's, we'll see. Here's an older pic.
69f100, that is pretty much what I plan on doing thanks for sharing. I'll have some questions for you in the future.
Currently I'll run what came with the car which is unknown white drag shocks and stock springs all around with traction bars. This car was a street racer and had a 302 with a tunnel ram, c6 and 8" before i got it. When I get the scratch it'll be caltracs and their shocks. Putting in the roll cage/sub-frame connectors wiped out my budget for few weeks. I bought this car as a roller in primer and am just getting it going. It'll be my first time at the strip.
Sounds like a good plan ...Keep us updated and good luck!
nice looking ride just let me know I will help you on what I know which is not much as some of the others
Be very careful with the flimsy grill. It wont take much pressure to snap it if you lean on it ... Hard to find a replacement for it ...
bigjohn2007- BBF CONTRIBUTOR
Thanks bigjohn.
Dave, mine has already suffered some breakage haha. It's held on by strips of metal and some screws now. It's solid but if i do find one in good condition someday I'll grab it. I get lucky on ebay every once in a while.
Get on You Tube and learn how to weld plastic...It works.
I know what I want for Hanukkah!
Nice car !! But isn't that really a 70 Falcon???? Which to me is even cooler!!! Still wish I had my 70 Torino 429SCJ car it was quick with just a few mods!!!
jeffgfg- Posts : 338
Well I guess it is! I just checked the VIN and it has a 26 body code which the torino cobra website lists as Falcon sedan. I wonder if there's any difference?
Actually the way I noticed was the frame around the door window, only Falcons had that. It actually is a 70 1/2 Falcon as there is a 70 falcon based on the 68-69 Fairlane. Your Falcon is pretty rare you don't see a lot of them. What engine did it come with?? They were available with anything from a 6 cyl to a 429SCJ. I always wanted one to put my SCJ drive train in. They are rumored to be stiffer than a regular Torino because of the "post" at the back window/door area. Good luck with it again I love it!!!
Wow jeff thanks for pointing that out! The guy I bought it from is a hardcore ford fan and told me it was a torino, had it for 2 years thinking that. Never would have guessed it was a Falcon. I didn't even know there was a 70 1/2 model.
According to the VIN it was built in Atlanta and originally had a straight 6 with an automatic.
Sweet ride man! Welcome to the site.---RED
61coon- Posts : 1824
» Letting the Cat out of the Bag !
» Building oil pressure when letting off
» Hi, thanks for letting me join - 1969 Marquis 429ci/4v
