Which Cam Bearings to use for the street Dura Bond FP-26-1 or FP-26T
I would like to know if these cam bearing will fit a a460 block, This motor is going to be a street / stip motor but mostly for the street. I have read that some guys are using the Dura Bond FP-26-1. I was looking at these cam bearing FP-26T beacuse they are coated. Can anybody tell me if these bearings are better than the FP-26-1 and will they fit my block?
CHARLIEB- Posts : 145
Re: Which Cam Bearings to use for the street Dura Bond FP-26-1 or FP-26T
CHARLIEB wrote:I would like to know if these cam bearing will fit a a460 block, This motor is going to be a street / stip motor but mostly for the street. I have read that some guys are using the Dura Bond FP-26-1. I was looking at these cam bearing FP-26T beacuse they are coated. Can anybody tell me if these bearings are better than the FP-26-1 and will they fit my block?
The FP-26-1 are #1 journal cleveland cam bearings....what you need to do a 460 Ford is have 5 of them coated or not.
[quote="Lem Evans"]
Thank You Sir, That is what I need it to know. I did not want to order thenm and send back because before I had ordered roller bearings and I was told not to use them on the street.
Thank You again for your advise.
The rollers are not a drop in deal, either. Machining the block (along with a couple other oiling mods) would be required.
maverick- BBF CONTRIBUTOR
» Dura-Bond FP-30AT
» So…? K-B pistons have mutable top ring gap setting why then is there such a big difference in gap between street and tow. 4.400 x .0065=.028 street
» AN fittings for street street car (brakes)
» Dura spark info
» Dura Spark II
» Dura spark info
» Dura Spark II
