1969 Ford F-250 with 429
1969 Ford F-250 with 429 Empty 1969 Ford F-250 with 429
Post  karlatteberry May 27th 2013, 12:05 am
Hi everyone - I have a 1969 F250 that my father put a 429 into back in 1970. The other thing he did was put 3.07 gears into a Dana 61 replacing the 4.10 stock gears. I have since put 33 inch tires on and have found that pulling my 6000 lb boat plus the weight of the truck and gear - puts me over 12,000 lbs. I have the cascades I pull over to go boating and am running around 1900 rpm (which feels a bit low). I need to change the gears and have the choice of 3.54, 3.73 or back to 4.10. RPM at 60 mph would be 2163, 2279, and 2505 respetively (http://www.csgnetwork.com/multirpmcalc.html) if this site is accurate?? Does anyone have the original stock torque and HP curves for the thunderjet engine? I also know my dad changed out the piston and rings to drop the compression ratio (I think to 8.5:1) due to lower octane fuel and detonation. Which would be the best gears to put in given my typical weight I'm pulling - while still trying to be semi conscious of fuel economy. I am leaning towards the 3.73's. What is the redline of this engine as well??
Thanks in advance!!
Karl
karlatteberry
1969 Ford F-250 with 429 Empty Re: 1969 Ford F-250 with 429
Post  Dave C. May 27th 2013, 8:31 am
Welcome to the site . I cant answer ur question but Im sure you wont see the word " economy" very often around here. Smile
Dave C.
Post  dfree383 May 27th 2013, 8:50 am
an all stock older thunder jet would be good for 5000 rpm +/- Id be leary of the valve springs if they have never been replaced.
IMO either the 3.54's or 3.73's would be a great choice.
and like Dave C has said BBF's and fuel economy don't go together very well.
Post  bruno May 27th 2013, 9:50 am
welcome to the site
http://WWW.CKRME.COM
Post  HorsinAround August 2nd 2013, 3:28 pm
Dave C. wrote:Welcome to the site . I cant answer ur question but Im sure you wont see the word " economy" very often around here. Smile
Why, I always thought 2 gallons to the 1/4 mile wasn't too bad. Laughing
http://www.frontpagefab.com
Post  dfree383 August 6th 2013, 6:18 am
FPG not MPG....... Amount of Fun Per Gallon !
