eliminator block oil restricting
i had a piston to head issue take a bearing out of my 605 this weekend and found another problem,i think .the lifter oiling is restricted with a 1/4"plug behind the other plug.i did drill the little .060 or so hole in it and got all kinds of oil up top which aint realy been a problem.now that i got it out and back down to clean all the bearing stuff out i took all the plugs out and noticed as i sprayed out the holes that the rear main is made just like the front.the priority oil galley is drilled all the way through into the lifter galley so....it needs a plug in the back too? a plug in front and no plug in back dont restrict the top as i see it.i dont see how the oil psi would check any different at the back than the front as i've read but not tried discuss..............
Re: eliminator block oil restricting
If my memory is correct, Lem was talking about this the other day. Apparently there are some Eliminator blocks out there, where the individual main galleys are drilled all the way through the priority oil galley and on into the lifter oil galley. So, at this point I would check it out and see if #2, #3, and #4 go on up into the lifter galley. If so, then the orfices in the restrictor plugs are essentially useless.
Uncle Charlie
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
i'll look again but i think it's just the #1 and #5. this makes me think some of my psi trouble at shut down could be related.c.evans wrote:If my memory is correct, Lem was talking about this the other day. Apparently there are some Eliminator blocks out there, where the individual main galleys are drilled all the way through the priority oil galley and on into the lifter oil galley. So, at this point I would check it out and see if #2, #3, and #4 go on up into the lifter galley. If so, then the orfices in the restrictor plugs are essentially useless.
Uncle Charlie
Uncle Charlie
That's not what he is addressing but, he should look at that issue too.
His issue is that some Elim. blocks...maybe all later blocks have the upper and lower gallerys connected at the rear unlike the early units....the A460 blocks are connected at the rear.
That being the case, the rear needs a plug in it also or there is no restriction of oil to the lifter gallery.
thats how i see it.i'll plug the back and see how it does.Lem Evans wrote:c.evans wrote:If my memory is correct, Lem was talking about this the other day. Apparently there are some Eliminator blocks out there, where the individual main galleys are drilled all the way through the priority oil galley and on into the lifter oil galley. So, at this point I would check it out and see if #2, #3, and #4 go on up into the lifter galley. If so, then the orfices in the restrictor plugs are essentially useless.
Uncle Charlie
Uncle Charlie
the first few/run of blocks done by LMS were drilled into the lifter feed.
DanH- Posts : 1081
DanH,
Good info. Is there any way for the Average Joe to identify which blocks these may be,,,,,,by external markings??
Charlie Evans
Charlie Evans
That would be good to know.i should'nt have missed itc.evans wrote:DanH,
Charlie Evans
cool40 wrote:That would be good to know.i should'nt have missed itc.evans wrote:DanH,
Charlie Evans
At the end of the day us guys that put things together have gotta catch stuff like that. But it'd be cool if those that had info about a material matter like this would have shared before now....Please refer to my post about the lack of oiling with the Morel lifters .
Engine building is an exercise in eyeballing everything
One neat trick I was shown years ago was to put the block in the solvent tank. Hook up a hose to the solvent pump and put the other end of the hose up to the oil passage feed. Gives a good visual of where the oil is going and if it is restricted. We caught a brand new Dart SBC block not feeding oil to one of the mains. Turned out was a broken drill in the main feed passage.
466cj- Posts : 391
» eliminator block
» wanted a460 block or eliminator block.
» wtb A460 block or Eliminator Block
» amount of time it takes to get eliminator block?
» WTB Eliminator block
