bbf
whitefield
airford1
cesarperez
bbf
i have a 70 maverick that i just installed a mustang 2 front end i want to put a 460 in it . what type of oilpan-headers and engine brackets for installation ? the other ? is what would be a good rearend setup because with the limited of front end travel with the mustang2 frontend . donot want to go with 4link donot want to cutup car thanks again guys
cesarperez- Posts : 19
Re: bbf
Then you should rethink the 460 and make the whole thing easy with a 5.0 and c4.
airford1- Posts : 192
Re: bbf
Fox pan and headers, ladder bars and floaters all cheap to do. very little cutting.
Re: bbf
you can go pretty damn fast w a ladderbar too......
Re: bbf
Caltracs for the rear and a good set of adj. shocks on all four corners stock 4cyl springs in front ( used ) . bbf. fox body headers will work too!
http://calvertracing.com/caltracs.php
whitefield- Posts : 2244
Re: bbf
. X2richter69 wrote:you can go pretty damn fast w a ladderbar too......
Re: bbf
If it's going to see a decent amount of street use I wouldn't use ladder bars. Also if you do go with either a ladder bar or a "drag racing" style 4-link setup plan on installing either a roll bar or a roll cage to help support the rear suspension structure & frame rails.
DILLIGASDAVE- Posts : 2262
Re: bbf
Did you have to cut on it to get the mustang 2 under it?
Dave C.- Posts : 1268
Re: bbf
Smith bars on the factory leafs and a good shock all the way around.
whatbumper- Posts : 3024
Re: bbf
DILLIGASDAVE wrote:If it's going to see a decent amount of street use I wouldn't use ladder bars. Also if you do go with either a ladder bar or a "drag racing" style 4-link setup plan on installing either a roll bar or a roll cage to help support the rear suspension structure & frame rails.
What Dave said^^^^^^^^^about the cage. A Maverick is a "flexible flyer" until you stiffen it. A good big block with traction could probably twist the windows out of it.
maverick- BBF CONTRIBUTOR
