balancer
balancer
Are all harmonic balancer id bores the same 302 thru 460?????? 1.375"?????How much press fit??????????
thanks
thanks
prospeedmachine- Posts : 8
Re: balancer
depends on the balancer manufacture and whos crankshaft.
Some balancers require a hone to fit properly.
balancer
does any body know the bore question ???????prospeedmachine wrote:Are all harmonic balancer id bores the same 302 thru 460?????? 1.375"?????How much press fit??????????
thanks
Re: balancer
prospeedmachine wrote:does any body know the bore question ???????prospeedmachine wrote:Are all harmonic balancer id bores the same 302 thru 460?????? 1.375"?????How much press fit??????????
thanks
Not the MOD motors.
Re: balancer
I found specs. at Professional Products that states sbf & bbf balancers all have a 1.375 bore???prospeedmachine wrote:Are all harmonic balancer id bores the same 302 thru 460?????? 1.375"?????How much press fit??????????
thanks
I am assembling a old pro stock 810 c.i. engine. the crank is 6" stroke, Bryant with 351c snout. just trying to find out if a stock 460 balancer will work as i do not have one ????? will never turn over 4000 rpm, as i am installing in restored 69 F100 with a c6 trany. also what is the lest ratio i can get for a 9" ford rear gear, would like to have a
2.0 or less?
thanks
Re: balancer
I'd have a balancer built for it. Those long stroke engines move around a whole lot and have totaly different frequencies the OEM motors.
Talk with ATI or Innovators West.
Re: balancer
looked at Innovators West web site & informed that a internal balanced engine the correct word is damper, not balancer. Thanks guys.dfree383 wrote:I'd have a balancer built for it. Those long stroke engines move around a whole lot and have totaly different frequencies the OEM motors.
