C6 trans help
C6 trans help Empty C6 trans help
Post  droppedf100 October 21st 2009, 6:16 pm
My trans is cracked around the top bellhousing bolt but not quite broke off yet. It needs a rebulid anyhow so should I get another case or have it welded?
Also, will a normal shift kit still work with a big cam? I have a full manual now and I hate it plus it still flares from 2nd to 3rd.
droppedf100
droppedf100
C6 trans help Empty Re: C6 trans help
Post  69F100 October 21st 2009, 10:23 pm
If I was you I would go to the junk yard and get a usable case if you are going to rebuild anyway. I have welded my share of alum the cast alum will take a special wire or tig rod the cast has alot of magnesume. It don't weld real good but it can be welded but will crack back open if not prepaired right and welded right and tends to crack right beside the weld. Just me I would replace it and if it was already built I would try to have or weld it and try it. shift kit ? I don't know asking about the same ? in the tran section.
Jim
Post  billandlori October 21st 2009, 11:10 pm
X2 on the replacement case. Aluminum is funny stuff when welded.
Frank Merkl should be whipping out his famous valve bodies soon. No more flair!!
Bill
Post  the Coug October 22nd 2009, 8:11 am
where have you got the trans and engine mounted in the truck?
Post  bluef100fe October 22nd 2009, 10:34 am
I'm running a welded case the top ear was broke on mine also. I've also ran the Turbo Action Cheetah forward pattern manual/automatic valvebody. It worked really well in my buddies 10 second falcon and in my 12 second truck. If your after a good valvebody that will shift on its own when in drive and hold any gear as long as you want it to when racing then I'd give that valvebody a try. Worked great for us. Hope this helps.
bluef100fe
bluef100fe
Post  droppedf100 October 22nd 2009, 11:50 am
OK im going to get a new case. I have another trans with a shift kit that lost 2nd awhle back so Ill rebuild that. If it doesn't shift good ill check out the Cheetah kit or the B&M kit that Frank Merkl recommended on the other site.
Coug, the motor is mounted in the stock position using L & L rubber mounts and a stock trans crossmember with a rubber mount and a chain hooked to the head for an engine limiter. It broke 2 drivers side motor mounts.
Thanks for the help.
droppedf100
droppedf100
Post  the Coug October 22nd 2009, 1:05 pm
The reason I ask was some guy's use a motor plate and have a mid plate and trans mount and the saying is you can use either two but not all three. it gets in a bind and the weakest parts break....
Post  droppedf100 October 23rd 2009, 12:39 am
Yeah im pretty sure I cracked mine by using the top bolts to pull the trans to the motor. I know your not supposed to and now I know why lol.
droppedf100
droppedf100
