external oil pump
external oil pump
rebuilding 810 ci" engine, for 69 F100. just wondering if i could use a 2 stage external oil pump,1 stage for engine & 1 stage for power steering. any idea of psi required for stock power steering sector. street rod only.
thanks
thanks
prospeedmachine- Posts : 8
Re: external oil pump
Bad idea IMO. I'd want to keep the systems seperated.
Power steering pumps are low volume/high pressure. The drive pulley on the external pump would need to be a completely different tooth count for the P/S than it would for the engine oil.prospeedmachine wrote:rebuilding 810 ci" engine, for 69 F100. just wondering if i could use a 2 stage external oil pump,1 stage for engine & 1 stage for power steering. any idea of psi required for stock power steering sector. street rod only.
thanks
Paul
