Proportioning Valves and brake lines
Proportioning Valves and brake lines Empty Proportioning Valves and brake lines
Post  HorsinAround June 12th 2013, 3:38 pm
Need some recommendations on a proportioning valve for my 95 150 build. This will be strictly a drag truck and will be disc front and rear. It looks like 3 basic types. fixed f/r and adjustable f/r and single
Fixed;
http://www.summitracing.com/parts/tff-2302nb/overview/
Adjustable;
http://www.summitracing.com/parts/sum-g3910/overview/
Single;
http://www.summitracing.com/parts/sum-g3905/overview/
Also, what size brake lines should I run? I believe the stock ones were 3/16 (or the metric equiv.).
http://www.frontpagefab.com
Proportioning Valves and brake lines Empty Re: Proportioning Valves and brake lines
Post  jbozzelle June 13th 2013, 11:20 am
That single should do fine.
 3/16 is fine for the line
Post  dfree383 June 13th 2013, 12:03 pm
I'd do an adjustable one if your replacing the factory part.
Post  IDT-572 June 13th 2013, 8:36 pm
When your running slicks at the track you can run a ton more bias to the rear brakes. The adjustable ones are nice for that.Cool
Post  cool40 June 14th 2013, 12:20 am
i used the wilwood on the front line. some good info.... http://www.markwilliams.com/braketech.aspx
Proportioning Valves and brake lines Tubsin002
Post  HorsinAround June 14th 2013, 8:41 am
That is some good info, thank you! Here everything I was reading was telling me to put the portioning valve on the rear line but with the skinny fronts, it makes sense to put more bias to the rear.
Post  IDT-572 June 18th 2013, 11:16 pm
I put mine on the rear brake line, and mounted it to the left of the drivers seat with the adjustment knob coming through the floor. I can adjust it on the fly.
Post  cool40 June 18th 2013, 11:22 pm
i just went by this.....
http://www.swracecars.com/Files/SW-Race-Cars-Vol-31-Pg49.pdf
