Transmission mount question
kjett
I'm using a motor plate to mount the engine in my wagon. As far as the transmission mount goes do I want to use an OEM style rubber mount or should I use a urethane mount like this one http://www.latemodelrestoration.com/item/LRS-6068AU/79-98-Ford-Mustang-Urethane-Trans-Mount or this one http://www.latemodelrestoration.com/item/PT-61604BL/79-98-Mustang-Urethane-Transmission-Mount and should I keep the rubber bushings in the cross member or should I use something like these http://www.latemodelrestoration.com/item/PT-61603BL/82-93-Mustang-Urethane-Trans-Crossmember-Bushings
Mike R- Posts : 1381
Re: Transmission mount question
I was told when I did my motor and mid plates to keep the rubber mount for the transmission. The thought was that with the solid mounting of the motor, if you also solid mounted the trans it would likely break the case if you have frame flex. The rubber mount will allow for some "give" and save your case.
kjett- Posts : 1169
rubber mount
Thanks guys
So if i go to my local part store what (year/model) should i have them look the tranny mount up?
bigjohn2007- BBF CONTRIBUTOR
bigjohn2007 wrote:So if i go to my local part store what (year/model) should i have them look the tranny mount up?
get one for a glide in a fox body.
If your talking glide... Get one for a 62-67 nova. That's what I asked for. Was like $6 or something.
whatbumper- Posts : 3024
Yeswhatbumper wrote:If your talking glide... Get one for a 62-67 nova. That's what I asked for. Was like $6 or something.
Did you use stock crossmember or fab one up?I got the mount but im using a crossmember i ordered for mustang/glide and it to high the mount want go between tranny and crossmember.
We had that on a stock mustang one. We just cut the tack welds on the ends and slid it around for the glide. I still use that same mount for the cross members that we build now. I'm not familiar with the crossmember you speak of though.
» stupid Question Transmission mount
» Question regarding SFI bellhousing for auto transmission, and Automatic Transmission Flexplate Shield
» Transmission mount
» C6 mount question
» Tranny mount question
» C6 mount question
