OIL DRAINBACK
+7
342g
David Willingham
Northwest outlaw
XYPROSTREET
11 posters
OIL DRAINBACK Empty OIL DRAINBACK
Post  XYPROSTREET October 22nd 2009, 6:36 am
Hi All, just wondering whether you think the front of the block oil drainback mods would still be neccesary on a front pickup sump.
(Drag Use ).
XYPROSTREET
OIL DRAINBACK Empty Re: OIL DRAINBACK
Post  maverick October 22nd 2009, 8:29 am
Oil drainback is ALWAYS important to me.....front and rear. I'd do it.
Post  XYPROSTREET October 22nd 2009, 9:15 am
That's what i thought just needed to make sure before i got the drill out.
Thanks Maverick
XYPROSTREET
Post  the Coug October 22nd 2009, 9:18 am
before you get the drill out make sure you read Paul Kanes instructions if you are a small amount off you hit water.. so read it and make sure...
Post  XYPROSTREET October 22nd 2009, 9:22 am
Yeh i seen his website i have been studying his instructions for a few days might have to take some prozac to keep the drill steady. Very Happy
XYPROSTREET
Post  the Coug October 22nd 2009, 9:27 am
just hate to see someone drill it and hit water, not a good thing then you have to get another block... be careful..
Post  XYPROSTREET October 22nd 2009, 9:33 am
Yeh i hear you any advice is good advice that's why we are on here.
XYPROSTREET
Post  Northwest outlaw October 22nd 2009, 10:30 am
When i did my block i started small and worked up the drill size. hope that helps out a little.
OIL DRAINBACK 095
OIL DRAINBACK 096
OIL DRAINBACK 098
Northwest outlaw
Northwest outlaw
Post  David Willingham October 22nd 2009, 11:23 am
Do it. It's not a big deal. You would really have to screw up to hit water. The biggest thing is to be very careful when the dril breaks thru. It will want to grab and "screw" the bit in and hit the driver's side cylinder bank. Also, be sure to take a die grinder and grind a nice radius on both sides of the holes and be sure to drill your holes so that they are even with the bottom of lifter valley so all the oil will flow out. I usually take my 3/8" egg burr and run thru the hole making a slight downhill slope out the front and then a nice radius down the front of the block.
David Willingham
David Willingham
Post  bbf-falcon October 22nd 2009, 12:31 pm
David Willingham wrote:Do it. It's not a big deal. You would really have to screw up to hit water. The biggest thing is to be very careful when the dril breaks thru. It will want to grab and "screw" the bit in and hit the driver's side cylinder bank. Also, be sure to take a die grinder and grind a nice radius on both sides of the holes and be sure to drill your holes so that they are even with the bottom of lifter valley so all the oil will flow out. I usually take my 3/8" egg burr and run thru the hole making a slight downhill slope out the front and then a nice radius down the front of the block.
X2. I've did quite a few of these,and I actually enjoy doing it. If you follow Paul's lead you will be fine. The one that I always say a prayer before I do is the one from the front cam bearing to the dizzy gear. I'm always scared of breaking that little bit off in the hole. affraid
Post  342g October 22nd 2009, 5:40 pm
If you enjoy doing it, why didn't you do mine before I brought it home. Very Happy Now I have to screw it up. Laughing Laughing
342g
342g
Post  XYPROSTREET October 22nd 2009, 7:15 pm
You guys are great, would the front cam hole to dizzy still be exposed with a roller cam bearing installed or would i have to knock it out i haven't got the block at home to check?
XYPROSTREET
Post  bbf-falcon October 22nd 2009, 9:32 pm
342g wrote:If you enjoy doing it, why didn't you do mine before I brought it home. Very Happy Now I have to screw it up. Laughing Laughing
Bring it w/you Wednesday Harold, and we will do it Smile You can be my shop bitch for the day Shocked Laughing
Post  chuck stevens October 22nd 2009, 9:34 pm
If you have roller cam bearings you must grind a shallow grove, to connect the oil passages, in the front cam bearing bore BEFORE installing the front roller cam bearing.
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  XYPROSTREET October 22nd 2009, 9:57 pm
I think thats's already been done Chuck is that the one that feeds the cam thrust plate you talking about?
XYPROSTREET
Post  342g October 23rd 2009, 1:44 am
I'll do that, pm, me your home address, so I can put it in my gps.
342g
342g
Post  bbf-falcon October 23rd 2009, 5:00 am
you got it Very Happy
Post  XYPROSTREET October 23rd 2009, 5:30 am
chuck stevens wrote:If you have roller cam bearings you must grind a shallow grove, to connect the oil passages, in the front cam bearing bore BEFORE installing the front roller cam bearing.
You got me worried coz i don't trust some machine shops so i knocked out the roller bearings tonight and to my suprise it has been done it has one shallow groove connecting the two passages and one feeding the cam thrust plate so all i have to do is the dizzy mod (not looking forward to it) i did notice however that they didn't tap and grub screw the main tunnel feeds to cam bearings as suggested by SVO in there instructions should i do this ?
Thanks Again
XYPROSTREET
Post  chuck stevens October 23rd 2009, 1:21 pm
NO. If you look at the stock front cam bearing you will see a groove from 6 O'clock to about 3:30. That connects the oil passages. That groove does not exist with roller cam bearings. It must be cut into the block ( I use a 1/8 ball burr in my DREMMEL tool) or NO oil will flow to the distributor stub.
chuck stevens
Post  XYPROSTREET October 23rd 2009, 7:08 pm
Yes I think you misunderstood me that groove has been cut into block,what do you think about the restrictors from the main feed to cam
as recommended by SVO. My lifter bores are not bushed also and i don't have restrictors in crossover should i bush lifter bores or just do crossover restrictors. Sorry about all the questions just want to make sure everything is done right while the engine is apart and there's alot of knowledge on this forum.
Last edited by XYPROSTREET on October 24th 2009, 5:31 am; edited 1 time in total (Reason for editing : Block Description Mistake)
XYPROSTREET
Post  chuck stevens October 23rd 2009, 9:37 pm
I'm not aware of anybody that is still restricting oil to the cam bearings any more. They need all the help they can get. I use the wider cam bearing sets available from at least 2 vendors,,,on this site. BTY, most avoid using CLEVITE cam bearings. Duro-bond seem to work better.
chuck stevens
Post  XYPROSTREET October 23rd 2009, 9:54 pm
So Chuck does that that still apply to roller cam bearings and what do you think about the lifter bore & crossover scenario i was talking about.
XYPROSTREET
Post  chuck stevens October 24th 2009, 11:57 am
If you look at the roller cam bearings...you'll notice that there are NO oil holes in them. They block the oil passage when they are pulled in...so why would you need to block (or restrict) the holes again? As to the lifter bores...is there something wrong with them? Are they too big? Do you enjoy spending money to "fix" something that is not bad? Is there a reason to bush the lifter bores?
chuck stevens
Post  XYPROSTREET October 24th 2009, 6:42 pm
I thought they bush the lifter bores to help restrict oil flow sorry i asked geez
XYPROSTREET
Post  chuck stevens October 24th 2009, 10:03 pm
When using a stock block in a racing application it is not uncommon to bush the right bank of lifter bores if, A) they are worn excessively and/or B) when using a SFT or roller cam. You are correct, it's for oil control. (Do not do it with a hydraulic lifter cam). The reason to bush only the right side is that it's where the main oil gallery is. The left bank oiling can easily be control with a restrictor in the tower to limit oil flow to the left bank. As to the restrictor, a .125 hole is plenty large, a .090 is often used and, a .060 can work IF the bottom end clearances are tight. It often requires a change, or 2, to get it right for your engine. Burnt pushrod tips and smoking valve springs would indicate that the restrictor is to small. If you decide to bush the pight bank, it's advisable to drill the bushings corectly before installing them. If you drill to high or low you won't get oil thru the lifters to the top end. Oh, the cam, since you've got the roller bearings, be sure the cam is ground on a 8620 or 9310 billet. The rollers will eat anything softer.
chuck stevens
