Leaf spring setup ?
hillbillyerv
droppedf100
fordman460
jones
Leaf spring setup ? Empty Leaf spring setup ?
Post  jones October 22nd 2009, 4:31 pm
As you might now I have a 93 F150 that I hope to be drag racing soon. I have swapped out the 8.8 for a 9" and 3.50 gears and 29.5 tire.
My question revolves around the link / traction bar setup. I plan on building my own but I need to know how the link / traction bar effects the suspension. I have been told that the bar needs to be atleast 1/3 of the wheel base. Should I try to build it parrel to the ground?
The setups that are sold over the internet just bolt to the bottom of the leaf springs and use a bolt-on frame bracket. Where I want to weld a bracket to the axle almost like a ladder bar.
jones
Leaf spring setup ? Empty Re: Leaf spring setup ?
Post  jasonf October 22nd 2009, 5:27 pm
I have never seen one run parallel to the ground. They usually mount below the axle and below the front spring mount making them parallel to the spring. I made my own in the Pinto. Made some tabs and welded them to the leaf spring plate and made the front to plates that bolt to the front leaf spring mount. My bar length was the same as some 4 link bars I had so I just used them. If it ever stops raining I will try and get you some pics.
As far as ride it made the ride rougher but I didn't mind it.
Good luck
Post  jones October 22nd 2009, 5:41 pm
Something very simular to this.
http://www.teamjdm.com/shop/product_info.php?products_id=79
Instead of mounting the front bracket to the frame I was going to make a mount off my driveshaft safety loop.
jones
Leaf spring setup ? Empty Here is an idea. Look at the front mount. Shouldn't bind like this.
Post  fordman460 October 22nd 2009, 9:30 pm
Leaf spring setup ? Tbarfr10preview.php?i=1&u=14459390]Leaf spring setup ? Tracti10[/url]
fordman460
fordman460
Post  jones October 25th 2009, 12:22 am
Can any one tell me what the physics you have to over come to drage race a leaf spring suspension?
Is it just the simple fact that you want to keep the axle from moving fowards and backward?
Limiting it to a perfect up and down spring travel?
jones
Post  jones October 25th 2009, 12:25 am
fordman460 wrote:Leaf spring setup ? Tbarfr10preview.php?i=1&u=14459390]Leaf spring setup ? Tracti10[/url]
Wouldn't that setup allow a little slack for foward and backward movement.
jones
Leaf spring setup ? Empty Mounting it solid on the front requires...
Post  fordman460 October 25th 2009, 12:42 am
something like a housing floater. The spring allows the axle to move forward and back when it goes through it's up and down travel. A solid mount would create binding during this travel. What you are trying to prevent, with a bar like this, is called spring wrap up.
fordman460
fordman460
Post  droppedf100 October 28th 2009, 5:30 pm
My slapper bar ser-up has worked well for the 8 years I have had them. Very simple and the suspension doesnt bind like the long bar set-up. We put Cal-tracs on my dads 95 and havent got them to work very good as of yet but I really just put them on and set the preload as recommended for the base setting. Im sure they will work great once I mess with them. Biggest problem is the front doesn't lift to transfer weight. I have 90/10s but it wont come up in the front like my truck. It did get a 1.62 60 ft on a 150 shot but I didnt leave on the bottle.
droppedf100
droppedf100
Post  jones November 6th 2009, 4:21 pm
You mention the binding on the long bar setup. Do you have any more info on this, go into more detail, what have you heard?????
jones
Leaf spring setup ? Empty Long bar.
Post  fordman460 November 6th 2009, 9:18 pm
I think he may be referring to the bind you would get without a housing floater or link on the front mounting point like I posted.
fordman460
fordman460
Post  droppedf100 November 14th 2009, 4:50 pm
jones wrote:You mention the binding on the long bar setup. Do you have any more info on this, go into more detail, what have you heard?????
When you hook the long bars up they are solid to the front of the frame. They dont pivot like a caltrac bar so when the suspension tries to go down in the rear the bar tries to push the rear backwards. It seems to make them stiff.
droppedf100
droppedf100
Post  hillbillyerv November 28th 2009, 7:10 pm
i am going to attempt to build a set of ladder bars for my 63 stepside with leafs bought some plans off evilbay , Shocked will let you know how it works out. does any one if longer/shorter is better?
hillbillyerv
hillbillyerv
Post  canzus November 29th 2009, 1:36 am
If you wanna run a 4 link, 3 link, or ladder bar, think about this for a few seconds. What is at the rear of the leaf springs???
Ford had it figured out in the early 60s, And we can't figure it out today??? Come on, it ain't rocket surgery...
Suspect
canzus
canzus
Post  dirtbogger December 10th 2009, 2:47 pm
hillbillyerv wrote:i am going to attempt to build a set of ladder bars for my 63 stepside with leafs bought some plans off evilbay , Shocked will let you know how it works out. does any one if longer/shorter is better?
I ordered a set of those plan too! haven't got them yet, only been a couple day's. My understanding is longer for mud, which is what I run in and shorter for asphalt,and in mud they should be parallel with the frame
dirtbogger
Post  jasonf December 11th 2009, 8:37 pm
jones wrote:Can any one tell me what the physics you have to over come to drage race a leaf spring suspension?
It can't move forward and backwards because the front pivot point on a leaf spring is fixed. Just the rear can move (because of the shackle) to compensate for change in distance because it pivots off of the front mount.
Here is some info I found while looking for some pics.
http://www.afcoracing.com/tech_pages/leaf.shtml
http://www.competitionplus.com/2004_10_21/chassis.html
Post  jasonf December 11th 2009, 8:51 pm
continued from above post
fordman460 wrote:[url=https://servimg.com/image_[url=https://servimg.com/view/14459390/2]Leaf spring setup ? Tbarfr10
The reason the shackle is on the front of the torque arm (red bar) is to compensate for the difference in pivot points between the torque arm and the leaf spring. This type of suspension would be considered a 3-link.
Leaf spring setup ? Ladderbar
Post  bcr466 December 13th 2009, 4:30 am
Jones, I know you said you were building your own, but my cousin's S 10 drag truck that I have been tuning and driving has a 9" with leafs and uses Slidealinks. They do a good job and are very easy to adjust although they were on the truck when they got it with no instructions. I have just been guessing at it, but even at that they do a good job with no binding.
bcr466
bcr466
http://cracing@frontiernet.net
Leaf spring setup ? Empty travel
Post  1lowet February 20th 2010, 6:15 am
the travel arc or pattern is different for bars verses leaf springs.therefore floaters are neededto let suspenion travel with out binding .
1lowet
