spudders on brake
spudders on brake
i just put a new cam and vic jr on my sbf, before it was fine, it would go 4500 on brake no problem and 3000 on the foot now if i try to use the tranny brake the sec i try to give it gas it spudders and dies. or even footbrake .any thoughts?
johndickjr- Posts : 896
Re: spudders on brake
carb might need more pump shot w the bigger cam and intake.
ill try that, currently has 31 front --32 backrichter69 wrote:carb might need more pump shot w the bigger cam and intake.
may need bigger 50cc pumps also
front and back ?richter69 wrote:may need bigger 50cc pumps also
also it did have 11 inch of vacuum and now has 5inches but i did not change the p.v and its a 6.5..if its a 6.5 and i only have 5 inches it opening at ideal correct ?
yeah its possible. Id plug the pv and jet up 6 sizes or so and see if that helps.
Yeah, either plug em or put 3.5 's in it. The PV needs to be less than the vacuum reading . Might need to advance the initial timing also.
Dave C.- Posts : 1268
