C6 with 2nd to 3rd flare
whitefield
64 fairlane
C6 with 2nd to 3rd flare Empty C6 with 2nd to 3rd flare
Post  64 fairlane July 15th 2013, 1:30 pm
Hi guys! I have a an issue with 2nd to 3rd shift. My question is after making 4 passes in about an hour and half the last pass had an issue making 2nd to 3rd shift it was really lazy going into 3rd. Do you think that the tranny oil temp could be the problem or is there a tranny issue. I don't have a tranny temp guage so I don't know the temp of the tranny. I never ran that many passes in that short of time. If more info is needed let me know, Thanks Aaron
64 fairlane
64 fairlane
C6 with 2nd to 3rd flare Empty Re: C6 with 2nd to 3rd flare
Post  whitefield July 15th 2013, 3:56 pm
64 fairlane wrote:Hi guys! I have a an issue with 2nd to 3rd shift. My question is after making 4 passes in about an hour and half the last pass had an issue making 2nd to 3rd shift it was really lazy going into 3rd. Do you think that the tranny oil temp could be the problem or is there a tranny issue. I don't have a tranny temp guage so I don't know the temp of the tranny. I never ran that many passes in that short of time.  If more info is needed let me know, Thanks Aaron
What vb are you running brand TB or MVB. ?
Which servo ?
how large of a cooler and how deep is the trans pan?
How old is the trans ?
Band adjustment ?
Fluid type ?
what size and how old is the converter diameter and stall speed ?
Really sounds like direct clutch pack burned up !
whitefield
whitefield
Post  64 fairlane July 16th 2013, 5:58 pm
I use type F tranny fluid
converter has under 50 passes
I have a deep truck pan on it
I don't know what servo is in it
Stock valve body
the band was adjusted about 30 passes ago when I had the tranny apart to check it over.
I don't know what kind of cooler is on it, it looks like it's from transport truck.
Think I should try a different cooler and give it a try.
64 fairlane
64 fairlane
Post  64 fairlane July 16th 2013, 5:59 pm
9inch JW 4500 stall converter
64 fairlane
64 fairlane
Post  whitefield July 16th 2013, 10:09 pm
Sounds like direct clutch is burned up ! How much hp and how old is trans or how many passes are on it ?
whitefield
whitefield
Post  64 fairlane July 17th 2013, 6:11 pm
around 750hp, maybe 40 passes on it.
64 fairlane
64 fairlane
Post  richter69 July 17th 2013, 6:28 pm
pull the pan, if there is black stuff in it your yankin it out.....
Post  460vega July 17th 2013, 7:29 pm
750 hp, stock valve body?
460vega
460vega
Post  69F100 July 18th 2013, 12:04 am
I know my stock c6 and stock vb with b&m shift kit wouldn't hold it flared up real bad on 2nd to 3rd shift with the 552 it should be a good 700 to 750hp engine. It held great behind the 460 making over 500hp but 700 to 750 on a stock trans is pushing it limits the way I see it.
Post  Gregaust July 18th 2013, 6:45 am
Still with 3 clutches in the top drum???
Gregaust
Post  64 fairlane July 18th 2013, 7:32 pm
still has the 3 clutch drum, if I pull the pan and find that it has clutch material in the pan, what improvements should I do to beef it up.
64 fairlane
64 fairlane
Post  64 fairlane July 18th 2013, 7:37 pm
I'm going to pull the pan on sunday, I will keep you guy's posted as to what I find. Thanks for the help guy's
64 fairlane
64 fairlane
Post  bigblok2000ranger July 18th 2013, 7:55 pm
64 fairlane wrote:still has the 3 clutch drum, if I pull the pan and find that it has clutch material in the pan, what improvements should I do to beef it up.
http://www.460ford.com/forum/showthread.php?t=105603
http://www.460ford.com/forum/showthread.php?t=105057
bigblok2000ranger
bigblok2000ranger
Post  whitefield July 18th 2013, 11:47 pm
5 on 5 clutch packs with a good servo and a Frank Merkl valve body or a manual valve body from Jay at Broader Performance. deep pan and large trans cooler. that's just my two cent! good luck
whitefield
whitefield
Post  64 fairlane August 25th 2013, 12:30 am
Sorry for taking so long to post my findings, I pulled the pan on my C6 today and there was a layer of black at the bottom of the pan. I guess the tranny is coming out. Thanks for the help. Aaron
64 fairlane
64 fairlane
Post  Gregaust August 25th 2013, 5:15 am
See how you go. The stock 3 clutches and VB need fixing. Stick some pics up, a few improvements and back together will be sweet . Need 5 clutches and a good valvebody
Gregaust
Post  64 fairlane February 28th 2014, 4:27 pm
I'm thinking about buying a C6 from broader performance. The C6 that i'm looking at is the 1000 hp C6. Do you guys think this a good way to go? http://www.broaderperformance.com/10-ford-c6-
64 fairlane
64 fairlane
Post  Gregaust February 28th 2014, 4:50 pm
I have bought quite a few parts from Broader and always been very good .
Gregaust
Post  whitefield February 28th 2014, 11:29 pm
I have bought several 1000 dollars worth of parts from him with no issues ! I am currently running one of his valve bodies .very good person to deal with
whitefield
whitefield
