1250 ultra dominator
1250 ultra dominator Empty 1250 ultra dominator
Post  BradB July 18th 2013, 11:13 pm
Anyone have experience with the ultra dominators, specificly the 1250cfm version list# 80532-2? Have you had any luck getting it tuned decent on a 850ish hp engine without eliminating the 3rd circuit or replacing the metering blocks? Thanks
BradB
1250 ultra dominator Empty Re: 1250 ultra dominator
Post  rmcomprandy July 18th 2013, 11:21 pm
BradB wrote:Anyone have experience with the ultra dominators, specificly the 1250cfm version list# 80532-2?  Have you had any luck getting it tuned decent on a 850ish hp engine without eliminating the 3rd circuit or replacing the metering blocks? Thanks
SURE ... that exact part number. but the -1 not -2.
Post  BradB July 18th 2013, 11:34 pm
It came from holley with a pv in the front and 96 jets, no power valve in the rear and 106 jets. Wondering if I should try it as is or plug the front pv also and put 106's in it, 106 seems pretty big. 547ci, p51 heads, 14.5:1 comp, mafia intake, pulling truck app. All I hear it seems is the horror stories of the 3 circuit carbs. Just looking for a good place to start. This is the ultra dominator with the billet metering blocks and larger fuel bowls.
BradB
Post  rmcomprandy July 18th 2013, 11:56 pm
BradB wrote:It came from holley with a pv in the front and 96 jets, no power valve in the rear and 106 jets. Wondering if I should try it as is or plug the front pv also and put 106's in it, 106 seems pretty big. 547ci, p51 heads, 14.5:1 comp, mafia intake, pulling truck app. All I hear it seems is the horror stories of the 3 circuit carbs. Just looking for a good place to start. This is the ultra dominator with the billet metering blocks and larger fuel bowls.
With an .026" high speed bleed, that jetting will be close with NON-oxygenated gasoline.
Post  4thHorseman July 25th 2013, 1:08 pm
I run one on a 13:1 552ci P-51 headed BBF.  I'm at 5,000' elevation FWIW.  No pv's, 90's squared. I removed the intermediate bleeds completely and installed them in place of the idle bleeds.  Effectively leaned out both circuits and delayed the intermediate's action.  Tremendously improved in my application both strip performance during burnout, stage, & launch and street manners & cruising.
I would imagine your setup would need to be a tad richer given lower altitude.
4thHorseman
4thHorseman
