Mark Williams 27 spline Powerglide Yolk
Mark Williams 27 spline Powerglide Yolk Empty Mark Williams 27 spline Powerglide Yolk
Post  69bluehotrod July 23rd 2013, 11:47 am
Uses 1350 series U joint. Fits GM Powerglide and Turbo 350 trans with bushing tail housing. “D” = 5-13/16” Manufactured from high strength Heat treated 4340 steel forgings. 100% machining creates a perfect balanced part. weight 2.53#
$175.00 + the ride... obo
Mark Williams 27 spline Powerglide Yolk Powerglideyolk_zps1163ca19
69bluehotrod
69bluehotrod
http://rainbowvacuumsalesservice.com/
Mark Williams 27 spline Powerglide Yolk Empty Re: Mark Williams 27 spline Powerglide Yolk
Post  dr's wife racing July 24th 2013, 7:11 pm
Will this work with a roller tail housing?
dr's wife racing
dr's wife racing
Post  69bluehotrod July 25th 2013, 10:58 am
dr's wife racing wrote:Will this work with a roller tail housing?
it's for a standard tail housing.
69bluehotrod
69bluehotrod
Post  bbf-falcon July 25th 2013, 12:24 pm
I thin Mark Williams make some of the strongest parts on the market,BUT you really have to watch w/interchanging w/other brands such as Moser,strange etc. Lots and most of the time they will only work in the MW family of parts.Smile
Post  dr's wife racing July 25th 2013, 12:37 pm
I have heard this is a issue with MW stuff. Thanks ward
dr's wife racing
dr's wife racing
Post  69bluehotrod July 30th 2013, 4:44 pm
The differwnce between this MW & one for a roller tail shaft is the diameterof the part that slips into the trans, a roller tail shaft takes a spacific... there is NO compatibility issues if you have a standard tailshaft on a powerglide.... 27 spline PG is a 27 spline period!
3rd member however such as spool spline/axle spline from manufacture to manufacture (pitch of the cut on the teeth)
is where you need to pay attention...
69bluehotrod
69bluehotrod
Post  69bluehotrod August 6th 2013, 1:01 pm
$165.00
69bluehotrod
69bluehotrod
