shifter
Dave C.
pigs521bbf
Re: shifter
i have the TCI outlaw with the button on it.
Re: shifter
click to see full size.
I dont like the button on the shifter handle myself, most of the buttons the shifters use are cheap anyway.
Re: shifter
its the black thingy with tci on it...Dave C. wrote:I don't see the shifter.
Re: shifter
you just wish you had one. i had used a starter button in the floor by the shifter for years. if it works use it....richter69 wrote:click to see full size.
Re: shifter
There it is! I had to go to photo bucket to see it. For some reason the right side of the pic was cut off...
Dave C.- Posts : 1268
Re: shifter
ProBandit. I use a little microswitch from Radio Shack for the transbrake...real light touch.
maverick- BBF CONTRIBUTOR
Re: shifter
wire the clapper to a switch and you're done. You just need one more hand. That would be funny to watch though.Dave C. wrote:Clap on Clap off ftw.
70FB- BBF CONTRIBUTOR
Re: shifter
70FB wrote:wire the clapper to a switch and you're done. You just need one more hand. That would be funny to watch though.Dave C. wrote:Clap on Clap off ftw.
Just don't be applauding your win as your go thru the traps.
Re: shifter
has anyone have any issues with B&M pro ratchet shifter?
pigs521bbf- Posts : 173
Re: shifter
I got a pro ratchet never had any problems out of it I had it for about 4 years going to change the gates for the pg pattern going to put the trans brake button on the back side of the cover. So when I use the trans brake just reach over the top and push the button so when I shift I want be worry about hitting it, I don't want it on the steering wheel.pigs521bbf wrote:has anyone have any issues with B&M pro ratchet shifter?
Re: shifter
Precision Performance Products makes a damn nice shifter. Real thin & light weight. Available in both front and rear exit cable models so you don't have to turn a conventional front exit shifter ass-backwards for better cable angles/less cable binding that can happen in some car chassis designs-layouts.
DILLIGASDAVE- Posts : 2262
Re: shifter
(by DILLIGASDAVE on Wed Nov 20, 2013 2:04 am
Precision Performance Products makes a damn nice shifter. Real thin & light weight. Available in both front and rear exit cable models so you don't have to turn a conventional front exit shifter ass-backwards for better cable angles/less cable binding that can happen in some car chassis designs-layouts.)
Does precision make the shifter where the shifter patter can be 1-2-3-N-R-P?or have it https://www.429-460.com/t6252-anyone-have-a-pic-of-a-precision-performance-kwik-shift-shifter-installed? Do you if this is for a ford c6? How much?
Re: shifter
x2 for the Precision Product shifter. We run them in both of our Probes. One is a PH and the the other is a TH400. they make a nice button for the side of the stick that can be a Line lock or Transbrake
steven gregoire- Posts : 68
» Shifter SOLD Reduced - B&M Pro Ratchet Shifter & Parts
» C6 shifter
» need help wiring a electric shifter to a 7230 msd box
» C6 Shifter
» LOOKING FOR A SHIFTER
» C6 shifter
» C6 Shifter
