Timing Gear/cam retaining bolt
Timing Gear/cam retaining bolt Empty Timing Gear/cam retaining bolt
Post  HorsinAround August 12th 2013, 9:32 pm
Can some one give me the length of the timing gear retaining bolt? I'm guesstimating 7/16 x 2-1/2" fine thread. I had a fine thread 7/16 bolt to verify the diameter/thread but it was way too long. Also, what is the thickness and diameter of the washer?
I had kept the stock stuff, but this aftermarket cam has a larger diameter bolt.
Thank You,
AP
http://www.frontpagefab.com
Timing Gear/cam retaining bolt Empty Re: Timing Gear/cam retaining bolt
Post  rmcomprandy August 12th 2013, 9:51 pm
HorsinAround wrote:Can some one give me the length of the timing gear retaining bolt? I'm guesstimating 7/16 x 2-1/2" fine thread. I had a fine thread 7/16 bolt to verify the diameter/thread but it was way too long. Also, what is the thickness and diameter of the washer?
Thank You,
AP
The bolt is usually about 1 5/8" long. I normally use and alloy rod bolt of the correct length with a 3/16" thick hardened washer about 1 1/2" inches in siameter. (The washer is a Pioneer cam bolt washer for an FE engine but, I can't remember the part number).
Timing Gear/cam retaining bolt Empty bolt and washer.
Post  460pulling August 12th 2013, 10:23 pm
I bought a SBC mr. Gasket.  Damper Bolt and washer tossed the bolt in a bin. Used the washer it was grade 8 and big and thick. and a ARP 7/16 rod bolt.
Randy M. had sent me this awhile back hope it helps
"Normally I use a 7/16" 8740 or better rod bolt, (1.500" to 1.600" long), and an ARP #200-8717 hard 2" washer, .275" thick."
460pulling
Post  HorsinAround August 13th 2013, 9:14 am
Talked to one of the machinists here at work today and he is going to make a washer for me, then I will harden it tonight with the torch and some oil.
Post  rmcomprandy August 13th 2013, 4:57 pm
460pulling wrote:I bought a SBC mr. Gasket.  Damper Bolt and washer tossed the bolt in a bin. Used the washer it was grade 8 and big and thick. and a ARP 7/16 rod bolt.
Using that washer is for a high valve spring pressure valve train and a very high lift roller camshaft; (but, of course it will work with a cam and system which would survive lesser).
Post  hienergy557 August 13th 2013, 10:13 pm
HorsinAround wrote:Talked to one of the machinists here at work today and he is going to make a washer for me, then I will harden it tonight with the torch and some oil.
That's what Kaase said on one of the engine tech DVD's. IIRC hs said .400" thick.
hienergy557
hienergy557
