Victory Valve Stems Pitting ?
Anyone know why new valves that haven't ran 3 hours total' would have pitting above the valve guide area ?
Heads sit for about 3 months before i got them when i ordered them new, Then i had them in the boxes they came in for a little while in temp controlled shop , before installing...I have ask many people and no-one seems to know..Sent them back to victory and they say they polished and cleaned them up and they will be fine..Intake is TI and Exh is steel...I wont know till next week or so what they look like untill i get my heads back...First sent these in cause Victory said they would replace the valves, then later said they wouldn't..So i ask fri if these would be ok to run with nitrous and they said yes...Not sure i trust that answer....Victory also said it may have been the assy-lube they use at the shop where i bought them, that was put on the valves...
colormebad- Posts : 262
Re: Victory Valve Stems Pitting ?
Are you near a coast? As in a salt water coast. I have seen humidity and moisture from areas close to a coast cause pitting.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
deja vu......
Humidity is bad here at times in ms' but have heat & air in well insulated shop...Just confused...c.evans wrote:Are you near a coast? As in a salt water coast. I have seen humidity and moisture from areas close to a coast cause pitting.
Charlie
Well another thing,,,,and I know you have Victory valves,,,,but on the inside lid of box of Manley titanium valves there is a label saying not to clean them with fluorocarbons; meaning do not use BrakeClean of Carb cleaner. It attacks the plasma moly coating on the stems.
Charlie
Charlie
I wish that were the case , at least i would know something...These valves were never took out of the heads since they were bought new , except when i took 1 int and 1 exh to check piston-valve clearance...Both the two i took out looked fine...Its just when i sent the heads back for them to look at the exh valve tip wearing after 3 hours only of running, that they told me of this..c.evans wrote:Well another thing,,,,and I know you have Victory valves,,,,but on the inside lid of box of Manley titanium valves there is a label saying not to clean them with fluorocarbons; meaning do not use BrakeClean of Carb cleaner. It attacks the plasma moly coating on the stems.
Charlie
» some of my TFS Rockers are heavily pitted on bottom
» Kaase needs help on truck driveshaft ( Victory!)
» Victory Titanium Valves for C head/SOLD
» Going from Ferrea 2.20 valve to 2.25, Is there a better flowing valve for ported STREETS?
» valve cover studs for aluminum valve covers
