comp cams roller rockers........
comp cams roller rockers........ Empty comp cams roller rockers........
Post  james00 August 31st 2013, 9:39 pm
hi i got a ? would you run comp cams aluminum rockers with a solid lift cam. thanks
james00
comp cams roller rockers........ Empty Re: comp cams roller rockers........
Post  rmcomprandy August 31st 2013, 9:40 pm
james00 wrote:hi i got a ? would you run comp cams aluminum rockers with a solid lift cam. thanks
Comp Cams has more than one type aluminum rocker arm...
Post  james00 August 31st 2013, 9:45 pm
the part# is17045-16 i think they are extreme energy. i have right at a 600 lift cam
james00
Post  bbf-falcon September 1st 2013, 12:32 am
Why not? We run alum rockers w/850+ lift roller cams.
