WTB BBF Mechanical Roller Cam
Looking for a good roller cam for a 466 project. I am looking for something close to the following:
Lift .700 ish intake and exhaust
Dura @ .050". Low to mid-250's on intake, low to mid-260's on exhaust
LS 108
LS 108
Rich Osmond- Posts : 217
Re: WTB BBF Mechanical Roller Cam
I have a brand new one ill let go with about 10 minutes of engine stand time on it . Bought it for a 466 build and ended up with a 545 . It's double pinned. Ill dig up the card if you're interested .
Dave C.- Posts : 1268
I might have one that fits that criteria... will have to do some digging... need lifters or anything else?
bluef100fe- Posts : 379
466 Roller Cam
Thanks for your response. I still need a cam, pushrods, stud girdles and locks. Any help is greatly appreciated!
Which heads are you using?
466 Roller Cam
Blue Thunder CJ with Chevy exhaust ports.
I don't know what length pushrods you need but I have a few sets to choose from...
Roller cam
Thanks. I will get back to you on that once I get the engine mocked up and can determine what I need.
Rich, the specs on it are .714 in .684 ex 266 /272 @.050 108 ls .
Roller Cam
Thanks Dave. I have one now that is:
.714/.714
266/274
110LS
I think this one is a big on the large size (duration) for my 12:1 466, and hence why I was looking for a different cam. Your is pretty close to the one I have. Thanks very much for taking the time to determine what you had.
.714/.714
266/274
110LS
If I have the one left that I think I have on the shelf its 252/260@ .050 and after lash it would be rite at .700 net lift. 108 LSA.. will check asap.
Roller cam
Thanks, that one sounds better. I will wait to hear from you. Thanks
Roller Cam
Bump - still looking
I have this one brand new still in the box.
647-inch lift Intake and Exhaust lift
Intake duration @.050-inch - 254 degrees
Exhaust duration @.050-inch - 258 degrees
112 degree lobe separation
107 intake lobe centerline
res0rli9- BBF CONTRIBUTOR
Roller cam
Thanks, I sent you a PM.
Not too big if you have a good convertor and gearing.Rich Osmond wrote:Thanks Dave. I have one now that is:
.714/.714
266/274
110LS
Cam
Thanks. Can you provide make and part #? Also how much do you want for it?
Rolls cam
Thanks everyone, I think I will run the one I have. I have a good converter for it and the dynamic compression ratio calc looks good. I will post the results when I get it to the track.
» mechanical roller cam question
» Comp Cams Mechanical Roller Lifters
» CompCams Mechanical Solid Roller Cam 296BR8
» Mechanical Roller Lifters New Crane in Box Good Price
» Crane Big Block Ford 68-97" 429 - 460 classic mechanical roller lifters BBF
